Pcv valve broke in top of motor. was pumping oil out of broke valve. Replaced pcv valve. Line is plugged at top of carb has a T in line with leg of T pointing at carb rest of line runs behind carb housing into another T one end toward oil tank other end to another T one end to drain plug and the other one to oiltank. Oil is pumping out of line directly into carb. Are these supposed to burn a mixture of gas and oil
SOURCE: i just replaced all oil
you dropped the oil pump it needs to be replaced again and new gaskets installed,you have to be very gentle with the pump they are so porly made.
SOURCE: Where is the oil drain plug?
on your left footpeg support there should be 2 hoses mounted on the inside; 1 is crankcase vent; other is oil tank drain... I always drain/open them both. worm clamps w/ plastic plugs
SOURCE: How to locate Crank case oil drain plug ??/
hi buddy its located underneith the engine where it always is remember to run the bike aswell before yo drain many thanks ollie reece-jones
SOURCE: speedo not working
in your wiring that you mentioned..check for connectors that look connected but may be loose.
SOURCE: pcv bypass and carburetor hook up
As far as the breather to the top of the engine goes, just pull off the hose and replace it with a small breather filter and you are good to go. Sorry, but can't help with your vaccum diagram.
