Question about KitchenAid KERA807P Electric Kitchen Range
KERS907 series electric ranges.
Based on your knowledge of repair history, would you recommend buying a Kitchenaid Architect series electric range (for example, KERA807 or KERS). I like its functionality, but Consumer-reports warns that kitchenaid has a bad repair record.
D
    Genius:
  • 1,073 Answers
Any high tech range or any appliance for that matter that is high tech has a greater risk of repairs, the smart solution is to purchase an extended warranty on the appliance so if it does need to be repaired it will not cost you any additional expense
btw kitchenaid makes a fine range
Posted on Apr 16, 2008
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
Fault code F2E0
Your key pad is shorted.Replace the electronic range control clock.
Mar 17, 2012 | KitchenAid Architect Series KEBC107KSS...
My KitchenAid Architect Series II Electric Range after I ran the self clean option the oven door will not open and the display does not light up, the top burners work just fine, tried ressetting the b
Hello Gene,
On the back of the oven is a thermal fuse that probably went outduring the sefl clean cycle,ya would need to pull the oven out and remove the back panel to test it, That thermal fuse is not resettable and must be replaced,it probably looks something like this 11_15_2011_7_41_32_pm.jpg
GENE
Nov 15, 2011 | Kitchen Ranges
I have a KitchenAid Architect KESC308LSS Electric Range and the stove top works fine but the oven is no longer getting hot.
After having checked the fuses, it would most likely be the oven switch because it is unlikely that both elements would go at the same time. Mane sure that the main switch is off when removing fuses to check them!
Jan 16, 2011 | KitchenAid KESC308LSS Electric Kitchen...
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
Oven elements not working but rest of oven does
try reseting your breakers may be partially triped if that dont work turn off breaker pull range out and chek the rower cord where it connects to the range if its burned on oneside replace cord and terminal block can get at lowes oven is fine just means cord wasnt tifhtned good when installed
Sep 23, 2007 | KitchenAid Architect Series KEBC107KSS...
KitchenAid KERA807P Electric Kitchen Range Logo
475 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
