Question about Indesit WA 125 Front Load Washer
Indesit wil 133
How do I get to the filter of my washing machine. I cannot find my manual anywhere. My machine is not emptying, it does when I remove the hose from the waste pipe and lay it down.
  • Indesit Master
  • 3,463 Answers
The filter is located behind a removable plastic panel on the bottom front of the m/c.
Posted on Dec 02, 2008
sounds like your inner door catch has gone common fault you can buy a new one on line from euro spares just put in your make model i can tell you how to fit
Nov 06, 2011 | Indesit W 123 Front Load Washer
Motor does not operate in desit wil 133
Remove the top panel and look for the tech sheets they will show how to enter certain modes to help locate the problem.
Sep 26, 2011 | Indesit W 123 Front Load Washer
The bearing on our wil 133 1300 machine has gone and I can't get it out. The screw is too tight to undo, do I need to undo it, is it a left hand thread etc.? I've tried wd40 overnight, no...
Just use the hammer to knock on the head and then use a chip chisel to punch on the sides.
Once the screw moves from the tight postion it will be easy to remove.
You need to use a correct head screw head to remove. If this has a flat cross handle your will be able to remove easily.
Jul 27, 2011 | Indesit W 123 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Indesit washing machine wixe127 has f04 faultcode starts cycle then empties and fills simultaneously
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Jan 25, 2010 | Washing Machines
I need to reset my delay timer on my wil133
how do i reset my indesit wil 133 machine as it wont start on any programme
Nov 27, 2009 | Indesit W 123 Front Load Washer
Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Sep 04, 2008 | Indesit W 123 Front Load Washer
Indesit WA 125 Front Load Washer Logo
216 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
