New LG Flatron 19 inch monitor
Picture not as sharp as I think it should be. Monitor says my video card won't support the recommended WXGA+ (1440 X 900). I want to upgrade but having never done this before I don't want to go over board getting a new card that does more than I need it to do . I basically use my computer for printing pictures from my camera or playing on line games that are not that into graphics but I do watch some DVD at times.
  • 180 Answers
Basically you ought to get a better card resolution if you need a sharp pict.
Posted on Apr 16, 2008
Automatically power saving mode ...........................cpu start working..........monitor power saving mode
Hook a spare monitor to the computer, if the same symptoms occur the problem is the Video Graphics Card in the computer, but if the picture is okay, it is clearly the LG Flatron that has the problem, and if possible sub the video cord from the computer to the monitor just to be sure.
Mar 10, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
Jun 11, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
Not able to use full screen
This sounds like bad resolution is set on your computer. The LG 22" FLATRON monitor has a native resolution of 1680 x 1050. However, your video card may not support this so you can also try any other 16:10 resolution like 1440 x 900.
To change your resolution in Windows XP:
1. Access the Control Panel.
2. Choose "Display".
3. Click the "Settings" tab.
4. Under "Screen resolution" move the slider to a 16:10 resolution like 1680 x 1050 or 1440 x 900.
If you computer does not support higher resolutions, you may consider replacing your video card to take full advantage of your nice 22" Flatron monitor.
If I can further assist you, please let me know.
Regards,
KYTechnology
Mar 01, 2011 | LG 22" FLATRON LCD Monitor
I have an acer Al1916W 19" LCD monitor. And the picture is off-center, it leaves about 1inch at the right side and a half in on the top, in 1400X900 res, and leaves about 3 inches of black at the left side...
The "native" resolution of the monitor is 1440 (not 1400) by 900.
Set the video-card to 1440-by-900 or try 1080-by-675 or try 720-by-450 or try 960-by-600.
Sep 13, 2010 | Acer AL1916W 19" LCD Monitor
My L G 19 "LCD Monitor showing analog power savings mode . How to solve it ? diliprakshit71@rediffmail.com
i think the problem is not the monitor but the inputs like the cpu where the video card or the rams are the culprit
Sep 03, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Flatron LCD Montor to a Dell Dimension XPS T500
> out of date?
Are you sure that it is "out of DATE" ???
Reconnect your old monitor.
Set the screen-resolution to 800-by-600 at 60 Hertz.
Shutdown.
Connect the new monitor.
Reboot.
The new monitor will be detected, and will run at 800 by 600 at 60 Hertz.
Change the screen-resolution to some higher value that both the new monitor, and your older video-card, will allow.
Jan 02, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
404 people viewed this question
David Payne
David Payne
