My father-in-law has given us an 8 year-old Toshiba 36ZP18Q TV. It worked perfectly at his house but refuses to work at ours! We get power through but no sound or picture. Nothing else is connected up to the TV. The green 'timer on' light flashes but that is the only activity. We've read through the user manual and followed the advice but to no avail. It's difficult to change menu settings, etc. without a picture! Any help would be greatly appreciated.
  • maz40 Apr 16, 2008
    Yes - the flashes are intermittent. Could you explain in layman's terms what you mean by marginal joints please? Are these the connections on the circuit board? Many thanks.
  • 4,234 Answers
Can you count the flashes or is it just continuous? If you knopw how to solder, try resoldering any connections that appear to be grainy or have rings. The move could have broken a couple of margnial joints.
keep us posted.
Dan
Posted on Apr 16, 2008
  • ABRsvcs Apr 17, 2008
    Yes, the marginal joints are on the main board. Any physical movement can jar loose these connections if they were marginal to begin with. Please note that these connections get this way not because of abuse, but because of heat/cooling cycles normal to TV operation. There are a few cables and connectors inside that may be a bit loose as well. Check those too for proper seating.
    As far as the video signal goes, the set should give you either a blue/blank screen or snow depending upon how it is set up. Try hitting the menu button, you should see the menu if the video section if functioning correctly as that does not involve an external signal. The menu is generated inside the TV.
    Keep us posted.
    Dan
    Genius:
  • 3,422 Answers
HI,
Do you hear any click sound?
ONE: The protection circuit is shutting the set down when you turn it on - to avoid further damage to the set.
TWO: The reason for the shut down is due to the protection circuit detecting excessive current in one or more sections of the tv.
THREE: The clicking sound is the ON relay getting shut OFF by the protection circuit. The thumping sound in the speakers is from the power supply coming up in voltage a little, and then shutting down.
FOUR: Number one reason for auto shut down in big screens is loss of high voltage. Number two is defective deflection amplifiers (horizontal or vertical amplifiers).
FIVE: These repairs are not something you can do at home; they require the service of a trained tv tech.
A Toshiba of this age is very marginal as to whether it is worth the repair investment. May be better off applying the money towards a new set.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Apr 16, 2008
    I also want you to cooperate with Benimur.I believe he can help you more with this.
    Brigadier General:
  • 6,966 Answers
A couple of possibilities:
1. While in transit, something must have jarred loose internally;
2. your post "...Nothing else is connected up to the TV..." might be causing a video/audio mute, have you tried connecting an aerial or cable to it?
3. try do a reset. Unplug the unit from the mains for a couple of hours and try again.
If problem persists, please try to determine if there is a sequence to & the number of times the "...green 'timer on' light flashes..."
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 1,665 Answers
Check the cord and if fuse in line input is blown.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 16, 2008
    There may be a loss of sync to the scan circuits, or there may be a response problem in the video path, thus not allowing proper sync.
    You would have to get the service manual, and trace through with a scope to see where this type of fault is. Also, checking for the proper supply voltages in the various stages would be a proper thing to do.
    If you are not trained and equipped in TV service, I would suggest to have the set properly looked after.
    Genius:
  • 1,142 Answers
You need to check the voltage input
  • Maanita Chadha
    Maanita Chadha Apr 16, 2008
    May be your father in law has a different rating of voltage at his place 110 and 220 volts are the choices may be you can check at the back of the tv whether it has a sliding switch.
  • Maanita Chadha
    Its gonna be a good move if you can hire a technician and get it installed by him.
Tip
My father-in-law broke his him a couple of years ago and his son bought and...
For this tutorial, I will be addressing a common problem experienced by many Samsung LCD, flat panel TV owners these day... "My Samsung TV keeps clicking for 20 minutes before it comes on" or "When I press the power button on my Samsung, nothing happens" or "When I turn my Samung TV on, there are white dots on the screen" or "When I turn my Samsung TV on, there are multi-color vertical lines on the screen"... there may be more, but these are the most common I know of. The models are numerous and seem to stretch from 08' - 09'. If you are having this issue and want to fix it yourself, read on.
TOOLS: #2 Philips Screwdriver, Wire Cutters, Soldering Iron, Desolder wick (with Rosin), Rosin Core Solder, Replacement parts (will be determined after disassembly).
The first thing we need to do is unplug the TV and move it to a good work location. You will need a soft place to place the TV, perhaps on a carpeted floor or on a blanket placed over the kitchen table ;).
Remove the 4 screw for the stand (RED area) and then pull the TV off the stand and place the TV face down on you soft work surface. Remove the 4 large screws (GREEN area) and the rear cover screws (YELLOW areas). Now remove the rear cover (screw location may vary depending on your exact model, so please make sure have them all out first).
Depending on your model, you may have a metal shield covering the boards. If not, you can skim ahead...
There are 2 major boards that will be front and center inside your TV. On the left we have the SMPS... this is where we will be working. So, we need to remove the shield cover to get to it.
Now that we have the cover off, we are able to take a closer look and locate the faulty parts. Have a look at the upper right corner of the SMPS (Switch Mode Power Supply). You will see a cable going over to the main board on the right... in this area you will find the problem.
The faulty parts are capacitors. The tops are generally swollen and often have blackened material exposed or leaking from their bulging tops.
You will need to identify the electrical value of the parts and locate suitable replacement parts (try Radio Shack). The values may be 1000uF 10v, or 2200uF 10v... whatever they may, you replacement part have an identical uF value but a higher v value... ex: Original, 1000uF 10v -> Replacement, 1000uF 16v. This will help prevent this problem from reoccurring.
Once you have the replacement parts, you are all set to install them. So, unplug the connection on the SMPS and remove the screws from the board. Heat up that soldering iron and remove the capacitors. Use the Desolder wick to clean up the pads, this will allow you to insert the new capacitors with ease. Be careful, these parts have polarity. This means that they need to be installed the same way you removed them... positive to positive and negative to negative. Each capacitor has a negative terminal, each mount location has a negative hole and it is indicated by the wide black band. After you insert each part, fold the legs over on the solder side of the board so that the part does not fall out and stays in position. Once you have all the parts reinstalled, solder them in. Make sure you make a clean electrical connection. Now use your wire cutters to trim the excess legs. Be sure to trim them close so that they don't touch any other electrical connections on the board.
Your SMPS is now fixed and ready to go... reinstall it into the TV and connect the wire harnesses back up to the SMPS. Double check your work. Are all the connectors back in place? Ok, now you should test your work before putting the whole TV back together. Prepare the AC cord, use an extension cord if needed. You will need to flip the TV up on to its top edge (upside down, screen facing you). Plug the AC cord into the TV and press the power button. Do you see the Video/Input indicator or RF snow on the screen? If so, well done! If not, unplug the TV and check you work.
You are now ready to reassemble the TV and return it to service.
** If you need some assistance in the soldering area, please have a look at my Tip "Soldering on the kitchen table, Class 101". I cover the actual soldering of a capacitor in more detail there.
If you have found this helpful, spread the word and/or leave me some feedback.
on Jun 22, 2010 | Televison & Video
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba 61H70 projection TV. Perfect picture but the sound suddently stopped working. Tried all on screen settings and still no sound. Set is 8 years old but relatively few hours. Is it worth repairing?...
it sounds like the soundboard went out on the tv..its probably worth fixing but you have to know what you are doing if you do it on your own.it could be something more minor too but not sure
Feb 24, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 36zp18q buzzing noise.
Humming sounds come from the power supply and buzzing sounds come from other circuitry. Most likely a capacitor somewhere.
Feb 18, 2009 | Toshiba 36A40 36" TV
Can not turn TV on
Failing power supply. It's 14 years old.
Feb 19, 2018 | Toshiba MD14F51 14 in. TV/DVD Combo
Toshiba 36 inch TV (8 Years Old)
If the shrinkage is just the top & bottom then it is relatively easy/low cost fix. Most probably, a capacitor in the vertical section is nearing end of its life. This would be the biggest of the bunch and would be something like 47uF/50V.
If however, the shrinkage is on all four sides, then it is the master power supply that is at fault. Chances are the main B+ is getting low which cold be caused by the big filter capacitor or an erratic regulator. This is not a simple fix and would require the services of a qualified professional.
Apr 10, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
