A two year old rarely used gas powered air compressor runs smoothly for an hour then just quits. Starts right back up then quits an hour later. Engine oil is good, pump oil is good, gas is fresh and carb is clean.
The problem that you describe could be fuel lock due to failure of vent system in gas cap. Easy to check; leave gas cap loose run engine as normal. If problem gone, replace cap with new vented cap. The newer gas caps (California caps) have much smaller vent holes that seem to clog when moving the compressor at too steep of angle causing gas to enter cap choking vent. Temp fix would be to cut small piece from rubber gasket large enough to let air to enter tank. Good luck with your repair.
