Question about Epson AcuLaser C1900 Printer
Prints black perfectly/colour print blank
Hi
i have an aculaser c1900 where when i print a black picture ,the unit print perfectly
but with colour my picture is blank
toner(cartridges new)
what do i do
please help
  • 27 Answers
The photoconductor unit may need replacing ? have you given your printer a service ? clean out all the dust from your unit making sure you dont touch the conductor unit do the best you can and try it again ok making sure the wast collector is empty too thanks
Posted on May 22, 2008
Hi. Epson C3000 aculaser. It is ghosting on only on black at a pitch of +/-62mm and also printing horizontal black smudges across both side of the paper at a pitch of +/- 25mm. I have totally cleaned the...
Hi Colin.
I just have had the same problem with my Aculaser C4200.
I may have found a way to solve you problem.
Just print 10 blank (without anything), and after that i took all toner's, the fuser etc. and put it back again. Printed 10 more blank pages, and printed over 200 pages with lot of tekst and colour (think that 50 pages could do it).
After 2 days everything is still ok for me.
Sep 30, 2010 | Epson AcuLaser C3000 Printer
How do I clean print heads re Epson Aculaser c900
you can clean print head unit
first remove opc and transfer belt ,then move front cover,then rmove
the Drum Unit Slide Cover,then
Remove the Laser Lens Cover.
now you can see printhead unit .Clean it and its ok.
Jun 07, 2009 | Epson AcuLaser C1900 Printer
EPSON AcuLaser C1900 paper jam when printing black or color
I have just gained a C1900 second-hand and have set it all up and got the drivers and so forth. Am having exactly this problem, right down to the folded pages, wide top margin and 'Check Paper Size' error message. Did you ever find a solution to this? Anyone else know how to fix it?
Jun 06, 2009 | Epson AcuLaser C1900 Printer
Epson aculaser c1900 error code e014
Error code 014 indicates that the cooling fan on the power supply board is not operating when the printer is switched on. Does n't explain the poor print quality though. I suspect it is a worn 2nd BTR roller (the black foam coloured roller inside the rear door). To check this send a coloured print through and press hard against the rear door during printing. If the print quality improves then it is a worn roller, if it doesn't let us know and we'll try something else.
Please take a moment to rate this solution. Thanks.
Mar 10, 2009 | Epson AcuLaser C1900 Printer
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
Service Req C0302
CPU Error. Mainboard is faulty.
Jul 04, 2008 | Epson AcuLaser C1900 Printer
K toner cart out, Epsom C1900 Aculaser color printer
i had the same problem as you i feel very upset with epson that they did not help you for me what i had to do is lay my printer on its side with the door to the toner facing you taking the toner out looking down into the bottom you will see a little plastic block wist it half way till it stops then reinsert the toner becarefull not to drop it in that shoud be fully fitted inside then put the unit back the right side up and start the printer up this shpuld fix your problem ok thanks
Feb 05, 2008 | Epson AcuLaser C1900 Printer
Epson AcuLaser C1900 starts printing too low
I have a C1900 with an error "Service Req E021". I appreciate any help as to what this refers to please.
Jan 05, 2008 | Epson AcuLaser C1900 Printer
Epson AcuLaser C1900 paper jams and almost no ink
If paper jam occurs frequently, wipe the pickup roller with a clean dampened cloth. Follow the steps below:
  1. Open Cover AB of the printer.
  2. Open the cover below the paper path roller.
  3. With a clean dampened cloth, wipe the pickup roller.
  4. Close Cover AB.
If the glass on the print head filter is dirty with toner, wipe it with a clean cloth. A vertical white line may appear in the printout. Follow the steps below:
  1. Open the front cover.
  2. Tilt the waste toner collector and pull it out.
  3. Grasp the handle of the print head filter with your fingers and gently pull it straight out of the slot. (**Note: Be careful not to spill toner that has accumulated on the print head filter. )
  4. With a clean cloth, wipe the glass surface of print head filter.
  5. Hold the print head filter by the handle and gently insert it all the way into the slot.
  6. Reinstall the waste toner collector.
  7. Close the front cover.
The print quality problem might be something as simple as turning off the Toner Save mode using the printer driver or the printer's control panel menus.
There may be a problem with the photoconductor unit. You may need to replace the photoconducter unit.
Or it might be something rather more serious (hopefully, not)Print out a status sheet. If a blank page is ejected, the problem may be with the printer. Turn off the printer and contact your dealer.
Jan 04, 2008 | Epson AcuLaser C1900 Printer
Aculaser c100 colour printing problem
Is the problem on all three colors? Is it possible someone has cleaned the toner transfer rolls - they have some "iron filings" to help the distribution and transfer of the toner. If this is the case you need a replacement toner roll assembly.
Nov 02, 2007 | Epson Aculaser C1100 Printer
Epson AcuLaser C1900 Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
