Question about Brother IntelliFAX 4100 Laser Fax
How do I receive calls on my fax? What should the mode be in?
How do I switch the mode to receive phone calls instead of faxes?
  • 328 Answers
Use the mode button in the upper right.
Posted on Aug 18, 2008
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon Fax Phone
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 12, 2008 | Canon FAX-JX200
Just brought a Fax JX200 and am having great diffuclty working out a problem , problem being we also have a 2 phone dual handset and the problem is when the phone rings it goes straight to fax on all 3...
1. Press [Menu].
9. Press [Stop].
Aug 11, 2008 | Office Equipment & Supplies
On a brother fax how do you set it to not go to fax mode on incoming calls
Depending on the model of fax some have switchs on the key board and some have switch in the set up menu. There are usually 3 or 4 answer modes. One for FAX or automatic receive, MANUAL to allow you to answer the phone and many have an ANSWER MACHINE mode to allow you to hook to ansering machine...What kind of fax do you have.
Aug 01, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Incoming Phone Ringer
After months of trying to solve this problem I finally figured out that the machine was set to phone/fax mode instead of fax only. If you have a dedicated fax line you can set to FAX ONLY MODE. In FAX ONLY MODE you can control whether or not the machine rings when it receives a fax call. You do this by selecting Data Registration, Press Set and use the up and down arrows to select 4. RX Settings. Press Set and use the up and down arrows to display the item you want to set or change and turn the ringer OFF. Press Set.
Mar 26, 2008 | Canon LaserClass 2050 Plain Paper Fax
How to not print faxes after hours
simply go into modes Fax/telephone and select telephone mode only instead of fax/telephone mode there is really no way to set the fax to not take faxes after hours automatically as it is designed to receive telephone calls and faxes as the machine reconizes fax tone.
the only disadvantage to doing this is you will have to change mode on a daily basis back to Fax/tel Mode during work hrs and back to telephone mode after hrs or simply uplug the phone cord going to the fax after hours
Jan 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Brother IntelliFAX 4100 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
