Question about Mercury Electronics CyberPix S-555V Digital Camera
PROBLEM IS UPGRADED TO VISTA CD ROM WILL NOT LOAD AND ONY HAVE XP CD
  • 6284 Aug 08, 2008
    Please HELP!!! I have a new computer and I tried loading my FujiFilm software and it will not allow it. I need compatibilty with XPS Vista. How did I achieve this????
    Thank you for your help. Darlene
Please advise as to what or where I go to download this info. Darlene
Posted on Aug 08, 2008
RM Z91FR laptop I want to remove the windows "Vista Ultimate" operating system and go back to XP Vista has slowed the machine drastically and filled the HD. I also want to instal a larger HD...
try to format all your drive by deleting your partition..insert your xp cd room boot with cd room press enter, press f8 press esc, press d, press l, then press c and enter
May 06, 2011 | ASUS Computers & Internet
I have acer aspire 4520.I have upgraded to windows xp sp2. The empowering technology does not work.It says " the specified file is not found".I cannot find the empowering technology software...
Acer Aspire 4520 Notebook Technical Specifications:
Operating System Genuine Windows Vista Home Premium Processor AMD Athlon™ 64 X2 Dual-Core Processor TK-57 (512KB L2 cache, 1.9GHz) Chipset NVIDIA nForce 610M Memory 1GB (1GB installed in one of two memory slots) DDR2 667 SDRAM User upgradeable up to 4GB (one 2GB memory card in each slot)* subject to availability of 2GB cards
*If upgrading after initial purchase, one or more of the memory cards provided with the system may have to be replaced with optional larger memory cards in order to achieve the maximum capacity.
Storage 120GB* hard disk drive Integrated variable-speed Super-Multi drive (DVD+R, DVD-R, DVD-RAM):
-Read - 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
-Write - 24X CD-R, 10X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
5-in-1 card reader for optional MultiMediaCard™, Secure Digital card, Memory Stick, Memory Stick PRO™ or xD-Picture Card™
Surely to load XP is a DownGrade. As this notebook is dual core, I would run Vista 64 or better still Windows 7 64.
If you wish to persist with an old system, you require SP3 for XP.That may be available from a software store but is no longer supported by Windows.
Try http://www.notebook-driver.com/laptops-information/acer-aspire-4520-notebook-technical-specifications/ for drivers that you will require to have support from Acer.
Hope that clarifies your situation.
Dec 09, 2010 | Acer Aspire 4520-5582 Notebook
The cd doesnt load that came with it, so no driver
Have you try loading the cd manually? If not here's how put the cd in your cd-rom or dvd whatever you have Xp or older you double click on my computer and double click on the cd rom or dvd rom. Vista click on start click on computer then find your disk drive.
Jul 23, 2009 | Microsoft LifeCam VX-1000 Personal Web...
Vista and Printhouse magic incompatability
Start "Help" within Vista.
Search for "Compatibility Wizard".
Launch this wizard.
Tell it that you have a "Windows XP" application that you want to install.
Point the wizard to the CD-ROM containing the software.
Install the software.
Now, when the software runs, Vista will create a "virtual XP" system, that will run the XP-only software.
Jul 21, 2009 | Corel Print House Magic 3.0 for PC
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Vista ultimate does not pick up dvd rom
how did you use it? where you using your dvd rom when you were still in vista basic then upgraded it to vista ultimate? if so, probably you havent installed the drivers for your dvd rom after upgrading to ultimate.
Feb 06, 2009 | Sony Optiarc AD-7170S Burner
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
CD Drive
You should not need a driver for your CD-Rom unless maybe you are upgrading from XP to vista. Most CD drives only require a generic driver to run, so unless you have upgraded your operating system, I would say that there is probably something physically wrong with it and it must be replaced.
Apr 12, 2008 | Toshiba Satellite M30 Notebook
How to install XP on pre loaded Vista in HP Laptop what can i do
make sure you have taken all the backup of your data from your system bcoz xp will not overwrite on vista you need to be format your drive which will erase your data. for installing windowx xp you need win xp cd as well as all the driver for win xp bcoz the driver is diffrent for vista and win xp . if you have windows xp bootable cd just place in your cd-rom or in dvd rom .and go to bios setup (bios setup is just press the del button from your keyboard or f2 key it is display whrn you start your system )and change the booting sequnce from hdd to cd rom when it will boot from cd one massage will come press any key to continue just press the space bar and follow the setup instruction . if you need more help let me know bye
Sep 28, 2007 | Microsoft Windows XP Professional With...
Mercury Electronics CyberPix S-555V Digital Camera Logo
Top Mercury Electronics Cameras Experts
Are you a Mercury Electronics Camera Expert? Answer questions, earn points and help others
