OmniPage scanner software is getting "unspecified error" after installing SP1
  • iantinoro Apr 17, 2008
    i have already done that
    with more troubleshooting, we found that the error
    comes up when running workflows, all workflows
    uninstalling SP1 did not work either
    Scholar:
  • 70 Answers
Uninstall the omnipage and reinstall again.
Posted on Apr 17, 2008
My Canoscan 4200F has no OCR software. How do I get it?
OCR software is usually a third-party program. Sometimes it is available on the original driver CD but it isn't included in the downloaded driver software. In the case of the CanoScan 4200F, the CD included the OmniPage SE OCR program. The SE indicates a Special Edition only bundled with the scanner and was only available for the OS versions that had been released when the scanner was first available. If you have the original CD (for Win98-XP), try to install the program using the Custom install option. (Check your current OS version. A 32-bit OS is more likely to support the OmniPage SE. With Windows Vista and 7, click Start > Control Panel > System and Security > System to determine the version. x64 indicates a 64-bit OS. ) If your current computer doesn't have an optical drive, use an external optical drive to install the program.
If you do not have the CD or your OS is incompatible with the Omnipage version on the CD, you will need to either purchase OmnuPage ($99 with a rebate from many vendors), AbbySoft's OCR program or one of the other OCR programs. SimpleOCR is free for personal use, http://www.simpleocr.com/Info.asp . The biggest problem with the free OCR programs is that they do not handle documents with columns properly.
I wish that I had better news for you.
May 31, 2012 | Canon CanoScan 4200F Flatbed Scanner
Cannot install Omnipage 18
get the old program that you have installed and click on it to get up the properties tab
click on compatibility tab
click in square and then high light win 7 click apply and ok
the fault is that you are getting the error message as you have a program already installed and if you want to install a later version of the program you will first have to go to programs and features in the control panel and uninstall omnipage program and all programs associated with the omnipage name
Jun 24, 2017 | Office Equipment & Supplies
Quick Question. I am trying to scan something and when I go to the application to open it up this is the message I get: "The application is unable to initialize and will close." Where should I...
You don't say which type of computer and operating system you are using. However, the answer is similar, regardless of the computer you're using. You probably updated your operating system, and the Agfa software no longer works. Depending on your operating system, there are various solutions you can use. Agfa no longer supports their scanners with new drivers or updated software. That's too bad, because they made some really good scanners for years.
A common solution I'm seeing on Mac, Linux, and PC platforms is to download and install SANE files on your computer and use graphics software, a different scanner program, or a direct interface with the scanner to continue using it. I'm on a Mac, and I'm using the Scan functions in Graphic Converter 7. I understand VueScan, OmniPage, Image Capture, PhotoShop (under some circumstances), and even Word will work, if the SANE files are properly set up. What works for you will depend on your own system.
Dec 30, 2010 | Agfa SnapScan 1212u Flatbed Scanner
I want to scan a paper and i want to save it as word so that i modify it. How can i do it?
It depends on if you have the full software installed. The MP160 documentation indicates it came wth ScanSoft OmniPage SE. Open MP Navigator and choose this program, you can output the scan as a text file. If you did a custom install, you may or may not have installed the program. If you omitted the program, do a new custom install.
OmniPage is an OCR program and will output to a number of formats (you will choose File, Save as) after scanning. Word can import RTF and most other choices as well as .doc files.
If you don't have the software disc, the software can be obtained from this URL:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Alternatively, there is a free OCR program (simpleOCR.com) that will do the same thing. However it doesn't handle text in columns (newspaper or magazines) very well.
I hope this helps.
Feb 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I am getting an error that says '' copy of prtection failure. There is no VRS file- import dongle connected.
You have a corrupted VRS setup - did you try to update the driver? The only way I could fix this problem was to uninstall all the scanner software (OneTouch, OmniPage, Driver and PaperPort) using the Control Panel, remove the \windows\Pixtran directory, run CCleaner's registry cleanup (might not be necessary) and reinstall the scanner software from the Xerox installation DVD. Took me the best part of one day to figure this out.
Nov 23, 2009 | Xerox DOCUMATE 515 SIMPLEX-FLTBF W/ ADF...
Omnipage not recognising Epson DX 4850 scanner (all in one)
Go to the Omnipage sight, they should post the scanners that have problems with their software. If you ahve the packaging, the guide should tell you or direct you a site that carries this information. Call Epson DX scanner or go on line to their site and query them about the problem, they should help. Go to the Contact Us. This should help you good luck
Jun 17, 2009 | ScanSoft OmniPage Pro 14
Cannot install omnipage se. wizard interupts process
When unistalled the previous Omnipage SE 4.0 and try to install new update vresion, an error message keep poping up saying a previous version of Omnipage is still installed in the computer and can not install the new version. No more trace is found for old version in Add/Remove screen. The problems are in the registry area. Just run regedit (export the registry as backup) and look for Scansoft under the software directory. Deleted all the Scansoft omnipage traces then restart the computer will solve the problem.
Nov 04, 2008 | Office Equipment & Supplies
I have purchased another computer and I am trying to re-install OmniPage Pro 12, and it keeps giving me a error message of some type of "Threat Detected!" Threat name: Frojan Hores Dropper...
Frozen **** are always a problem! hehe! It's possible that your new computer has a more sophisticated AntiVirus program on it, and it thinks your OCR software carries a Trojan Horse type of worm. If your Omnipage is a genuine disc, and the same disc that you used before, i'd suggest you disable your antivirus while installing the program. With Norton antivirus, you'd double-click the yellow circle/button in the system tray and then disable. Since you haven't mentioned which antivirus you have, i'll leave it to you to work that part out, eh? =-]
Aug 23, 2008 | Computers & Internet
Error message on Epson 1640 XL scanner
try to fix the usb cable or just replace it and reinstall the drive software disk. bye.
Sep 28, 2007 | Epson Expression 1640XL Pro Flatbed...
Communication problem?
Dear CrysC,
I had the same problem with my HP Officejet J5780. I just got it to work with a different paper size.
Don't ask me why this worked, but it did, so I guess that's all that matters.
In Omnipage, I went under the "Tools" menu and clicked on "Options." I then clicked on the tab, "Scanner." I changed the paper size to what I wanted (A 4). I then clicked on "Setup." Despite its recommendations not to do so, I reinstalled my scanner.
After the reinstall, it is now scanning the new paper size.
I hope that I don't have to do this everytime I scan a new paper size...
Douglas1966
Aug 28, 2007 | Canon DR-2580C Path-Through Scanner
186 people viewed this question
jasbo
jasbo
