Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
USB malfunction Ok, As i plug my HDD devices in (my mouse), after a certain time it will stop working. I have tried using all the different USB ports, but no sign of success. Help needed. PLEAAAAAAAAASSSSSSSSEEEEEEEEEE
    Sergeant:
  • 202 Answers
Hello jaybear
The most likely problem is your USB bus is underpowered for supporting your external hard disk drive along with other USB devices.
First, this is actually a good thing in a way. The reason is, it is actually telling you right up front that your USB bus is underpowered for this device. That's a huge improvement over issues caused by underpowered USB buses in the previous model computers. In those, we were left to having to figure out what the problem was when a USB device inexplicably stopped or didn't work.
What is happening is, your new hard disk drive(s) (HDD) are trying to run off of power supplied by your computer's USB "bus" (circuitry). This is OK for USB devices needing low power. But in the case of external hard disks, it's "iffy" whether there'll be enough power on the USB bus to support even one of them, much less two or more. Particularly on laptop computers.
Have no fear. This problem is easily remedied. :)
You need only attach an A/C adapter to each of your external hard disk drives and you should be OK.
If that is not an option, connect a **powered** USB hub to your laptop and plug the external HDDs into the hub instead.
By "powered" I mean a USB hub that comes w/ an A/C adapter. In either case, using a powered USB hub or attaching an A/C adapter to your hard disk drives will remove the external hard disks' power load from your laptop's USB bus and provide sufficient power for the HDDs to run.
You can find USB hubs at Newegg.com and lots of other online high tech stores. I like Newegg because their prices are competitive, their customer service is excellent and there're customer reviews of most of their products there as well.
If you have any more questions, comments, observations - anything at all, just let us know. We're here to help.
Otherwise, PLEASE, take a moment to rate the solution that best addresses your problem. If the solution provides a "fix" for your problem, then a **FIXYA** rating would be very much appreciated. :)
Thank you
BJ @:)
Posted on Apr 16, 2008
  • 1 more comment
  • B Joan Rapier
    B Joan Rapier Apr 16, 2008
    ** Please, disregard the 2nd paragraph of my 1st post. That part was intended for another Asker w/ a similar problem. My apologies for any confusion that paragraph might have caused **
  • B Joan Rapier
    This solution applies to laptop and to desktop computers. I was making the assumption that yours was a laptop as that is where I see most issues w/ low power on the USB bus. The remedy is the same in either case.
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello jaybar. I take the rating and your having closed the problem as good news - that my recommendation(s) corrected your issues and all your external USB devices are co-habitating nicely on your computer now.
    Fantastic!
    Thank you very much for the kind FIXYA rating. It is v-e-r-y much appreciated. :)
    Thank you for using FixYa. Please, come back anytime. We're happy to help.
    BJ @:)
Fix hard disk
with the device plugged in, open your device manager. The device should show a yellow exclamation mark next to it. Select it and delete it.
Unplug the device.
Power the computer completely off.
Plug the device into a different USB port (one you know works)
Boot it back up
If this doesn't fix it, repeat the process a few times with different ports and also using a different USB cable, if you have one.
If this still doesn't work, the troubleshooting gets significantly more complex.
Oct 22, 2013 | Transcend StoreJet Computers & Internet
My wireless mouse has stopped working
Wireless mice require batteries, unlike many USB, products, which are powered by the USB port; a wireless mouse is one of the devices that are not. Manufacturers, such as logitec and microsoft, have cleverly concealed the batteries inside the mouse, either under the place where your palm rests (older models) whereas newer models may have a battery compartment door underneath.
The only part powered by your USB port is the transmitter (the 'dongle') that is plugged into the USB port . You have to change the batteries every once in awhile. Some models put themselves into a sort off standby/off mode if you don't touch them for a certain period of time; others have tiny On/Off switches underneath. If you have one of those, remember to turn your mouse off, overnight, or when you aren't going to use it for long periods of time.
Thank You For Choosing FixYa~!
Mar 17, 2011 | Acer Computers & Internet
I have a toshiba satellite and after the most recent windows update my external mouse stopped working and says driver malfunction when i plug it in... i have tried everything system restore driver...
Try opening Device Manager in Control Panel and deleting the driver. Reboot, plug the mouse in again and see if that works.
Alternatively try restoring your PC to before your last update.
Dec 30, 2017 | Toshiba Satellite Computers & Internet
Mouse Problem- Not Working
i should reinstal his driver just to make sure is working properly,you can check in start-my computer-rightclick manage -device manager- usb then click on action button and Scan for hardware changes.
Dec 10, 2009 | Microsoft Comfort Optical Mouse 3000...
My usb for my mouse in malfunctioning
To me it seems that the power on button on the mouse is faulty. Check it on another PC. If it works 100% then plug it in a different USB port on your laptop. If the problem persists then the USB on your laptop has to be taken care of.
Nov 07, 2009 | Logitech VX Nano Cordless Laser Mouse
Acer USB Ports - Unknown Device - Will Run Mouse but not Printer
Sumtimez ports r damaged.somtimes not.. just chek other devices..if done..thn chek RAM!! lil chance tht u hv lost ur laptop!
Oct 12, 2009 | Acer Computers & Internet
When working on my computer Optiplex 745 Windows XP professional the optical mouse becomes non operative (no response, no red light). If I shut down and restart the computer it is fine.
Make sure the HDD jumper is set to master and see whether it helps.
If not the HDD is not recognised by the PC. Also make sure the connections between the HDD and mother board.
· Try a different IDE cable
· Try a different HDD an
All the best!
Jul 06, 2009 | Dell U0636 Mouse
On board USB ports not working
Right click the mouse on My computer located on desktop- select Manage- select device manager- find universal serial bus controllers - click on universal serial bus controllers - u find some devices there - right click the mouse on each and select uninstall - after uninstalling restarting the computer.
note : ensure usb controllers are enabled in BIOS setup for this , u should press delete key  at the startup of PC and locate it in Intergrated peripherals
Dec 20, 2008 | ASUS M2N-MX Motherboard
Mouse isnt working on laptop
hi.
Can u tell me which mouse do u use, brand and did u get drivers with it and which OS u use
Deepak
Oct 02, 2008 | Gateway MT3705 Notebook
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
