Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Scratches on stainles steel door
While trying to clean spill spots, i scratched door surface, how to fix it?
    Novelist:
  • 184 Answers
IF IT IS BRUSHED STAINLESS, AND THE SCRATCHES ARE REALLY BAD, YOU COULD TRY SOME STEEL WOOL TO SOFTEN THE SCRATCHES, BUT IT WILL BE A TRADE OFF OF MINIMIZING THE SCRATCHES AND CAUSING A SMEARED LOOK TO THE BRUSHED STAINLESS PATTERN.
Posted on Apr 16, 2008
Fix scratches on stainless steel appliance
The professionals in order to remove the scratches from st. steel they use special metal wire meshes like soft scotch bride attached on special rotary milling machine. They brush it in the direction of the grooves on the st. steel surface. They start with a hard brush and they reduce the strength until they finalise it as the original finish. If it a brush surface this is more easy than a polished mirror surface. These procedure need experience and care so you will not end up with more damage than the original one.
Dec 29, 2012 | Electrolux 30" Electric Hybrid...
Tip
Best way to Fix Scratches on Your Radiant Smooth top Cooktop
Cooktops are in many homes and are a preferred kitchen appliance to many home owners. The Cook in the kitchen can appreciate the stylish look of a sleek radiant smooth top Cooktop . Many invest top dollar to have stainless steel appliances including the following: Refrigerator, Dishwasher and Compactor. Moreover, having a sharp looking Cooktop addition only compliments the style and design of any high end kitchen. Maintainence and care of such an essential attractive appliance such as a cooktop is important.
Here is the best way to fix scratches on your Radiant Smooth top Cooktop:
Step 1 - Prepare your Cooktop by cleaning the surface*Make sure the surface is cooled* Use a damp rag first and sweep of crumbs and food stuff. Use your favorite cleaner and rinse completely. Careful not to get moisture around knobs or switches. Dry off surface.
Step 2 -- Work on the scratch area
Run the sharp edge of a razor over the scratch around 3x and this will aid in smoothing out any raised ruff edges. Apply gentle pressure to the cooktop scratch area.
Step 3 - Apply A Cooktop Cleaner
Use a few drops of cooktop cleaner to the scratch area. Use a sponge to rub in cleaner. Use circular motions to allow scratch to absorb product. Run the razor edge over scratch again making sure not to apply to much pressure.
Step 4 -- Clean Cooktop surface again and remove cleaning product
Rise off cleaner and dry with a dry paper towel. Inspect scratch to test results. Repeat step 3 until you have desired results.
Special Note* Their are many ceramic cleaning products to choose from and many claim to be the best on the market. Be sure to choose one that has good reviews and then test the results. Special attention must be given to all radiant smooth top cooktops. Be sure to use only cookware that is recommend by the manufacturer. And be sure to clean spills as soon the cooktop is cooled to keep the appliance looking well. Deep scratches or pits cannot be removed or buffed out and may lead to a cracked cooktop.
on Dec 16, 2010 | Kenmore Elite 44173 30 in. Electric...
Tip
How to Remove scratches outside refrigerator door
This tip is only for small scratches which are like hair sized one not more than that,If you have deeply scratched panels,you have to hire a professional to refinish them.
Today most of the refrigerator door come in stainless steel based plastic door.You can easily remove the small scratches on these door.
Steps to be followed:
1)Take white cloth and it should be a soft and dry one.
2)Buy stainless steel polish and squirt it on a small cloth and rub over the scratched area.So that it will get pasted over it.
3)Rub in one angle and in same direction.
4)Now rub the scratch with scouring pad over the surface of the polished scratch.
5)Buff with a clean cloth and remove the small particles so that it wont make more scratches.
6)Wait for 3 hours and take some water dipped cloth and wipe on it.
7)For deep scratch you have Teflon coating so that no more scratches will occur and also removes the deep scratches.
on Sep 01, 2010 | Refrigerators
Buying new cookware and need to know if Stainless steel will scratch the surface of smooth top.
stay with what you have been using. rachael ray has a unike design. try it.
May 23, 2009 | Kitchen Ranges
Stainless steel doors need to be polished
I've personally been performing restoration of high end metal surfaces, bronze, stainless steel, aluminum etc., including scratch removal, polishing, regraining, lacquering etc.. Strictly commercial properties, elevators escalators etc. I've performed these services for 30 years. As a Master Finisher I developed DeBruce Polish, and still perform metal restoration personally.
go to debrucepolish.com
contact: Bruce Smith
Apr 16, 2009 | Kitchen Ranges
Scratched stainless steel
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
use scotch brite #7447 get at automotive stores and blend scratches with the grain. If they still exist use 180 to 240 grit sandpaper and again finish with the 7447
Mar 29, 2009 | Kenmore 99123 Electric Kitchen Range
How to clean stainless steel
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Fingerprint stains on stainless steel fridge doors
going with the grain( s/s has grain just like wood product) try cleaning with a stainles steel cleanlingcloth and some wd40, this will remove any defect in th metal go with the grain not across you will leave rub marks if going avcross t he grain!!
Feb 12, 2009 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
I have the civilization IV game. when i first bought the game my computer had no problem installing it. i uninstalled later & now i can't get it to reinstall. it's as if the drive isn't reading the disc.
well thts seems your cd is scrached or else unreadable, you can repair your cd  Scratches can be repaired with a disc repair kit, available at any computer or music store. Follow the instructions carefully for best results. Unfortunately, not all scratches can be repaired. Sometimes, you just have to replace the disc. Water spots can also be a problem, and they don't usually respond to a scratch-repair kit. Beware of spilling sugary liquids like soda on your discs. Even if you wipe up the spill immediately, it leaves behind a sticky residue that will ruin a perfectly good disc by causing dirt, hair, and sweat to stick to the surface. Also, try not to touch the playable surface of the disc with your hands. Sweat contains salt, which will eventually cause tiny pits to form in the disc surface.
Dec 22, 2008 | Computers & Internet
SCRATCHED STAINLESS STEEL SINK
Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
Feb 08, 2008 | Kitchen Ranges
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
492 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
