Question about Sony Cyber-Shot DSC-S500 Digital Camera
Flash stoped working
My flash quit working all of a sudden. the little yellow light by the flash sign is flashing.
  • Anonymous May 15, 2008
    yellow point is flashing
  • mayukha Jul 16, 2008
    I also got the same problemas jmsmith74 all of a sudden. The flash is not working and when the camera is kept on Auto mode, there is acontinous flashing of yellow light next to flas and it is not allowing me to take any pictures.
Check your batteries. If you are using lithium ion batteries, they are strong enough to run the camera operations just fine, EXCEPT for the flash. After a couple of uses, the li ions are not strong enough to produce a volt burst strong enough to trigger the flash. Get the rechargable nickel hydride batteries recommended at sony.com.
Posted on Oct 31, 2008
  • 149 Answers
Make sure yor flash is turned on. You might have burnt out flash bulbs.
Posted on Jul 18, 2008
  • 2 more comments
  • john doe
    john doe Aug 08, 2008
    what your problem? IT might be that. Whats so inapropriate about that?
  • john doe
  • john doe
  • john doe
As driving the car, the Engine suddenly stops for a fraction of second (speedometer going down to zero and back up in speed) with the yellow Engine sign flashing (intermittently).
If the engine sign is flashing it usually means that the car needs IMMEDIATE ATTENTION. Put a code reader on the computer see what code it's calling out then go from there, it could be your TPS, IAC or your fuel pump, FP regulator or any of the associated wiring.
Mar 18, 2016 | Maruti Cars & Trucks
Im having a sudden problem with my Ps3. The fan cuts in for about 2 seconds and cuts out then it says no signal, then flashes yellow, then flashes red...does this mean its totally screwed or only a little?
Hello there sarah
If you have the brief flashing yellow light, then its followed by a red blinking light then you have the yellow light of death AKA the YLOD.
The lights are a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the YLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click here to know more on PS3 Fix Manuals which has helped so many people like you.
Good luck
Best regards
Peter
Sep 18, 2011 | Sony Playstation 3 (PS3) Console
41a5021-3e Yellow light on back flashing, and the remotes do not work. Tried to reprogram but still no luck.
Random flashing of that light is normal. Rapid flashing is a sign of interference. Make sure the light in the wall control is not flashing. If it is press and hold the lock button for 3 seconds. Your logic board may be bad.
Jan 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
430EX won't fire.
Can you short the pins to have the flash fired?a.l9609@gmail.com
May 27, 2009 | Canon Speedlite 430EX TTL Flash
Yellow light on sony grand wega
Probably hte lamp. You can replace this yourself.
May 10, 2009 | Televison & Video
You are correct in saying that the bulb needs to be replaced. Take the camera to any camera shop and they will replace it for you.
Apr 20, 2009 | Canon PowerShot SD1000 Digital Camera
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
Dec 12, 2008 | Nikon Coolpix S210 Digital Camera
Sony Cyber-Shot DSC-S500 Digital Camera Logo
268 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
