Duet washer WFW9200SQ00 display F20
I'm starting the wash cycle and it starts for 10 seconds and displays F20?
  • 5,911 Answers
"F20" is a water inlet problem. This indicates that you have no water or insufficient water supply. What Whirlpool recommends to do is unplug the washer and check your water inlet screens to ensure they are not clogged, check the inlet hoses for kinks, and to make sure your taps are turned on (duh! I know it sounds stupid, but I've seen it before).
To check the water inlet screens you will need to turn off the water supply and disconnect the hoses where they connect to the back of the washer. The inlet screens are located inside the tap fittings and sometimes will collect with sediment and rust depending on your water source. Some hoses also have sediment screens. Check them as well if you have them. Use cotton swabs to clean the screens, thoroughly.
Checking the hoses and taps is self-explanatory. The water supply coming into the washer should be at least 10-25 psi. Insufficient water pressure can cause problems with slow fills and/or error codes due to insufficient pressure. If you haven't had any problems before, I would suspect dirty inlet screens and/or a inlet valve failure.
If you need to replace the water inlet valve, searspartsdirect.com carries the part. Just type in your model number in the Search menu and look for item #1 under the "Dispenser Parts" heading (part #8182862). The part runs about $52.00.
I hope this helps you. If you need further assistance, please post back with any questions/concerns you may have.
Posted on Apr 16, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
The display is reading F20 Out of Order. I know that behind the frot panel, there is a way to reset the machine, I just can't remember what does it.
sadly many times when we learn something once we should write it down and put with owners manual . try unplugging it for a few minutes .
Dec 07, 2017 | Maytag Washing Machines
Code problem on the machine is F20
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
also, those flood prevention hoses they sell you don't work well with front load washers
Jul 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer has the "control
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
Jul 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Getting F20.
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I'm getting a F20 code?
“F20” on display
water supply)
Nov 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Error code f20 on the front loader
F20 code on whirlpool duet washer WFW9200SQ00
May 13, 2008 | Washing Machines
Washing Machines Logo
1,287 people viewed this question
Top Washing Machines Experts
