Question about Sony PlayStation Portable (PSP) Console
Psp question I try to delete the name "john" on my system. I do as instructions by using the delete button. it will not erase the name so I can put my name in. #2 problem--- do I need to insert the memory card each time I turn on my psp to play? #3--I have the game Suduko by Carol Vondermen. It is supposed to tell me if I put the wrong number- answer in, I am not able to make it do so. I am not that savvy with electronics. Can you help me with these questions? Thank you
Format the psp
Posted on Apr 17, 2008
How to add music onto my psp online
    1)Connect PSP to computer with USB supplied with PSP.
    2)Now, press "home" button on PSP
    3)Scroll down menu to option "setting" using right and left directional buttons
    4)When you reach the option "USB Connection", press X button to indicate your selection
    5)The "my computer" window will now show a removable drive
    6)Double click on removable drive to open it. You will see a folder named "PSP" inside it.
    7)Open the folder "PSP" and see whether there is a folder named "Music" inside it.
    8)If you cannot see the folder named "Music", then create it inside the folder named "PSP." Make sure to name it "Music".
    9)Now simply and paste the music files from hard disk to the "Music" folder, just the way you would transfer files from a CD to your hard disk.
    10)Once you are done, press the "o" button on your PSP. PSP will exit from the USB connection. Now unplug PSP from the USB data cable. Now you can carry around your music collection and listen to your favourite tunes, whenever you want. Enjoy!
How to put music on PSP from computer
Oct 31, 2015 | Sony PlayStation Portable (PSP) Console
How can i play the games from memeory card in psp 3000 slim model game
ok well i just bought mine but it was used and i looked at the official firmware and it was 4.20, so i used the official update 5.03 and then updated it to that official firmware and then i used chickhen for my firmware 5.03 and then i used Gen A to play psp and playstation games! if you look in system settings then look at system info youl will see ur firmware, if it is below 5.03 then use this method with these files
http://rapidshare.com/files/307164750/psp_3001_only_for_5.03_and_below.rar.html
ok download this file i made for you, then extract all 4 files.
extract psp 5.01 fw update and put the eboot file in a folder named UPDATE and place that folder in your psp. hook your psp up to your computer and go to psp then game and put the update folder in game.
now make sure you have a full battery or at least a half charged batt with the charger on it! repeat keep your chrager on at all times from now on. now go to ur psp and chose the game option and the update folder will be there and hit x and it will go to the update process and just hit yes and agree to the terms and it will update the psp to ofw 5.03 and it will ask to shutdown. now turn on the psp and check system info to see if it is 5.03. it should be
no hook the psp back up to the computer and go to the picture folder and delete and pictures you have. now extract the chickhen file and put the slim picture folder with the files in the picture folder. put the chckhen for psp slim in the picture folder on your psp[ make sure that the pictures are in the chickhen fold} just open the slim folder and put the chickhen folder in ur psp picture folder k
and make sure you also put the h.bin in the root of the psp. this means the first folder you see when you open the psp. if you dont know what root of a card is then find out, its the very first folder thing that comes up when you open ur psp memory stick on ur computer
ok see the folder psp and others thats your root. put the h.bin file there,
ok and now you can put the 5-03gen-for-hen files in your psp. hook uo your psp to the computer and go to PSP then GAME look to see what the name if your psp drive is and run the the file called lauch me in the gen file for hen and it will bring up a menu. select what psp you have 3001 for you and then chose full install and psp install chose yes and then put the drive letter or name in the psp unit drive box. for instance if your psp drive name is G then just put G. you can see what the drive name or letter is by looking at the root folder and look up at the right top corner and it will say the name. then hit start and it will finish pretty quicly.
ok now go to ur pictures folder and open the chickhen and dont press anything and it should load if not then try again and when it does go green and load go to ur game folder and run the installer loader file and the hit L or R to install custom firmware then whens its done hit O and it will load in the fully hacked mode which lets you play psp games and psx games as well.
you never have to install the custom firmware and but you have to uyse the loader every time you turn it completely off.
see when you turn it off completely then hack is gone but all you have to do is run Chickhen again from the picture folder the run the installer loader and hit just O and it will load fully hacked again. you must repeat this step when ypu turn it off
Nov 14, 2009 | Sony PlayStation Portable (PSP) Slim...
Connect a USB Cable.
do a full power off on the PSP, ie hold the power button for 5 seconds until it properly turns off. a short slide of the power button only puts it in standby mode.
also (on the PSP) check under Settings > USB Auto Connect (ON) - ensure this is enabled. makes it easy to connect USB with this turned on. but you need an up to date firmware on the PSP for this setting.
still no go?
try and restart the computer and plug the PSP back in once you have your desktop up.
Sep 22, 2009 | Sony PSP-3000 Silver Console
Erasing / Resetting names
To delete a player profile, go to the player profile screen and press and continue to hold down the following buttons in sequence: Home
A button
Left arrow
Then, touch the X icon that appears at the bottom of the screen and follow audio instructions.
Note: You can only delete a name when all three name slots are filled.
May 12, 2009 | Video Game Consoles & Games
Psp wireless internbet connection
get you a roiuter.. any router will do. you can get them cheap now at major retail stores. Once hooked up and running on your pc, turn your psp on.. make sure your "wlan" is turned on (top of your psp). go to network settings and go into that. go to infastrucure mode, hit x. highlight new connection. Your now in WLAN settings. go to scan and press the right button. Scanning will now take place. Your router is now available.. On SSID you will see the name of router, hit the right button, WEP , then hit right again.. you will need to put down the number given to you, when you installed the router on your pc.. its like a security number ( in case someone around your neighborhood tries to use it).. put in the number and press right.. save options.. and your ready to your internet browser. You can now update firmware at Network update too.. have fun.
Dec 09, 2008 | Sony PlayStation Portable (PSP) Console
About music
i have placed an answer to your previous premium post, this may work as well as my first suggestion and Marked's.
  1. Connect the PSP to your PC with a USB cable. (about $10: buy a USB cable for your PSP)
  2. Press the "home" button on the PSP (it's a tiny button to the lower left of the screen) then use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
  3. Press the "X" button (you got it, the round button with the "X" on it) and your PSP should display "USB Connection".
  4. In a moment or two your computer should tell you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
  5. Click on the drive letter that corresponds to the PSP unit.
  6. Now create a new folder on that drive and name it "psp".
  7. Within the new "psp" folder create another folder, and name it "music".
  8. Copy your desired mp3 files into the new "music" folder.
  9. When you're done copying your desired music tracks, press the "O" button on the PSP to get out of USB connect mode.
for more information click on the link below.
http://www.askdavetaylor.com/pc_to_sony_psp_how_do_i_download_music.html
hope this helps.
Aug 17, 2008 | Sony PlayStation Portable (PSP) Console
Deleting photos from your Canon PowerShot A60
You can download a manual (Camera User Guide) here.
1. To erase an image from the memory card, in Replay mode scroll until you see the image you want to erase on the LCD.
2. Press the Func button (this is also the erase button).
3. You will see two options, "Cancel" or "Erase"
4. Use the right arrow key to highlight "Erase"
5. Press the Set button (first button below the LCD)
Mar 20, 2008 | Canon PowerShot A60 Digital Camera
PSP Game not Loading
What is the name of the game that isn't loading? is the disk scratched? and do you plug your psp into your computer using usb? if so, if you unplug the psp withput stopping it on the windows desktop, it can sometimes corrupt or delete the data stored on the memory stick.
Mar 11, 2008 | Sony PlayStation Portable (PSP) Console
PSP Bricked?
Brick has two signs
A. semi bricked - your are able to go in the recovery menu (open your psp and hold the right trigger in 5 seconds)
B. fully brick - u can't go to the recovery and not charging
A.semi- brick
  • Things you will need:
  • A psp and a pandora Battery
  • 1.first download this padora file http://www.megaupload.com/?d=U4I65Q7F
  • 2. go to recovery mode of your psp
  • 3. then press toggle usb
  • 4.format the memory stick
  • 5.put the padora files root of the psp
  • 6.put the pandora battery in the psp
  • 7.press the x button when you see a menu
  • 8.then follow the instructions shown on the screen on psp
  • 9.your done you can now delete the files!
  • congratulations!!
B.Fully bricked
  • Things that you will need:
  • Card reader/writter
  • Pandora battery
  • 1.download the pandora files that use in semi bricked
  • 2.use the card reader/writter
  • 3.fomat the memory stick
  • 4.place the pandora files in the root of the memory stick
  • 5.put the memory stick in the psp
  • 7.press X button when u see a menu
  • 8.follow the instructions
  • 9.done u can now delete the files!
THATS ALL!!
Dec 04, 2006 | Sony PlayStation Portable (PSP) Console
PSP web browser
yes it can go to setting go down to system setting press x system language u can change it to what ever
Oct 20, 2005 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
