Question about Epson Aculaser C1100 Printer
Epson cx1100 e527 error
I replaced the C toner and closed the A door now my machine shows service req e527. How do I repair this error? Do I need to disassemble the machine? any help would be appreciated.
  • tommy_cx1100 Apr 16, 2008
    Is there anyway to remove the toner carriage?
  • tommy_cx1100 Apr 17, 2008
    These instructions are for a inkjet printer. I want to remove the part of the printer that the toner cartridge goes into. not the toner cartridge. Do you have a repair manual?
    Genius:
  • 1,142 Answers
Please provide the model and the make
Posted on Apr 16, 2008
The printer is giving me service error E527 what can be done to overcome this error
Hi Good day!!!
This error message "Service Req E527" means that the toner carousel housing the toner cartridges is obstructed, or is unable to rotate correctly. It can be caused by installing a toner cartridge incorrectly.
Solution 1:Check that the toner cartridge at the front of the printer is installed correctly.
Solution 2: Manually remove all of the toner cartridges.
Close all the covers, and then power the printer off.Open Cover B, and then remove the photo conductor unit (PCU).Turn the toner carousel by hand to line up a toner cartridge with the front of the printer.Open Cover A.If the toner cartridge is not in position to remove it, close Cover A and repeat the steps above.Remove the toner cartridge, and then close Cover A.Repeat all the steps above until you have removed all four toner cartridges.Reinstall the PCU.Close all the covers, and then power on the printer.Open Cover A and Cover B.Check thoroughly for any jammed paper, foreign objects or damaged parts.If you can locate an obstruction, remove it. Then, close all the covers and restart the printer again. If you can identify any damaged parts, there is an obstruction you cannot remove, or there is no change after restarting the printer, then contact Epson for further advice.Reinstall the toner cartridges (Follow the prompts on the LCD display), and then test the printer.
Don't forget to vote thanks!!!
Nov 02, 2010 | Epson ACULASER CX11NF All-In-One Printer
Service required E527
E527 indicates a developer home position error. With the front cover closed you should be able to freely rotate the cartridge "carousel" from the top with the PCU removed. If it does not rotate smoothly then something is broken and the printer will require stripping completely and the broken parts replaced. If this is the case then it is unlikely to be economically repairable. If the carousel does rotate freely however, then it is one of the following: Either the MCU (engine) Board itself is faulty, there is a wiring fault or the Sensor Rotary Home Position is faulty/dirty. The sensor is the first and most obvious thing to check but it requires taking off the L/H cover and removing the Low/High Voltage power supply board to get at it. I would recommend getting someone experienced at repairing printers to do this, but if you really want to give it a go then follow this link;
http://www.fixya.com/support/t1865287-epson_c1100_service_req_e527
Jul 27, 2009 | Epson Aculaser C1100 Printer
Cartridge jam carrousel blocked service req E527
Open the top cover, lift the orange PCU lever and lift out the PCU using the handle. With the front cover closed you should be able to rotate the Toner cartridge "carousel". If not then find and remove the blockage. If it does rotate then it is a sensor problem which involves stripping down the printer. I have helped with this problem before, just follow this link
Jul 05, 2009 | Epson Aculaser C1100 Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Cancel »
Jan 17, 2009 | Epson Aculaser C1100 Printer
Service req E527 error
Try this (as per Epson Tech Support): To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed (as you have already), the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall a stuck toner cartrdige.
I hope this works for you. Let me know please!
May 24, 2008 | Epson Aculaser C1100 Printer
Epson C1100 aculaser
E527 Dev home position sensor error:
Possible causes:
MOTOR ASSY MAG
SENSOR ROTARY HOME POSITION
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Apr 11, 2008 | Epson Aculaser C1100 Printer
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
Message error E527
What firmware version have you updated to? Check the sensor for the carousel. It could be that the sensor has got a nudged and knocked out of alignment. Remove the PCU and you will see the sensor on the left side above the carousel. Adjust it so it lines up better with the carousel. If it's still bad, check the sensor behind the LV/HV power supply. To do this you will need to remove the two power supply's. If you want a service manual with full details and error code translation get in touch with http://www.TheServiceManualShop.com (cheap as chips!)
Aug 14, 2007 | Epson Aculaser C1100 Printer
E547
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson. Check my previous post on this item: http://www.fixya.com/support/t154259-paper_jam_e547
Jun 15, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
304 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
