Question about Frigidaire FRS23R4A Side by Side Refrigerator
Frigidare side by side
The refrigerator compressor starts whinning and the refrigerator will stop cooling on both sides, then a week or so later it is back to normal for 3 or 4 months. I replaced the relay switch, that didn't work. The fan is running..?? The compressor keeps coming on occassionally and whinning, but not cooling. Almost like it is stuck in defrost mode.
  • 1 more comment
  • jh1523 Apr 30, 2008
    Our fridge (frs23h5asb6) has stopped working even though it is only a few years old.  The repairmen say it is the compressor and the problem is common in the fridgidaires and this model.  Cost to repair is too much to justify.  Do others have this problem?  is there any recourse with the company when the appliance is under ten-years-old.  Is this a diabolical way to condition us to purchase a service contract on future purchases?
  • rpank123 Aug 27, 2008
    Fridge side is working fine. Freezer went out. Turned too 5 on temp. dial fan came on but nothing else happening.
  • tomila25 Sep 08, 2008
    frigidaire side by side fr526hf7bw1 stops cooling and makes a buzzing sound about every 3min., did it about a month ago then started working, now it is doing it again
    Genius:
  • 1,073 Answers
You have a bad compressor
Posted on Apr 16, 2008
Intermittently starts beeping 3 times and some time later (hours to days) stops cooling. Works again, for a week or so, after unplugging for 10 minutes or so
Hi, your suggestion is good. Also consider an overbuild up of frost which the autodefrost can't cope with. I don't know what to suggest you do about it apart from minimising the moisture content of the food that you put into it.
Just seen your post regarding replacing the control unit yourself. I think that it's feasible if you have a reasonable amount of experience. However, the final decision is yours, I cannot suggest that this is something that you should do.
Jun 29, 2015 | Frigidaire Pro PHS69EJSS Stainless Steel...
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
It stoppped cooling. when i plug it in days later
Check out these tips that I wrote about that...it is a great place to start trouble shooting your unit...and something thatyou can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Kenmore Side by Side Refrigerator
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Our side by side refigerator is not cooling. We had sears come out and they replaced the computer board and said it would now cool. Two weeks later (today) they came back and replace the theromostat and...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Our side by side Frigidare ref. is not cooling as much as it should - ice is frozen but ice cream is not. Also runs pretty much all the time.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
sfgjsf
Jun 04, 2009 | Frigidaire FRS26R4A Side by Side...
Ref. side stops cooling intermittently. Replaced damper control but problem occurred again three weeks later.
HI,
The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
thanks,
May 19, 2009 | Frigidaire FRS23H7CS Side by Side...
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Frigidaire FRS23R4A Side by Side Refrigerator Logo
274 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
