There is a key symbol on the display and I can't do a cycle. It is a bosch exxcel 1200.
  • Anonymous Mar 18, 2014
    on the screen of the machine, there is a red key shape that lights up and the machine won't switch on anymore
  • Anonymous Mar 31, 2014
    Can't do a wash circle because there is key symbol on the display
    Champion:
  • 207 Answers
The machine won't start because the door isn't properly closed. However it might be that there's a problem with electric door lock itself. Try pushing the door a little bit more in to see if the lock will "click".
Posted on Apr 16, 2008
Does the Bosch Exxcel 7 1200 Express have a child lock function?
try the manufactures website for free manual download
Dec 08, 2013 | Bosch Washing Machines
Bosch exxcell 7 washing machine (1400) Power cut at home. Display now shows key symbol - 12 minutes 1200 spin speed Have tried unplugging. Controls will not reset
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Jul 08, 2011 | Bosch Washing Machines
Bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Jan 07, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
Have bosch classixx6 1200 express which has frozen displays a flashing key and 36 will not budge, desperate Molly
Simply press and hold the Start button for 4 seconds and the childproof lock will turn off - the key symbol will disappear from the display.
If you want to activate the lock then press and hold the Start button until the key symbol appears on the display.
Oct 22, 2009 | Bosch Washing Machines
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
need more info what point in the wash does it start to display the code
Sep 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washer has key symbol on display unit permanently
Go to this link (or copy and paste it into your browser if it doesn't post as a link); https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM third from the bottom is your user manual, second from the bottom is the quick reference guide. the key symbol is the childproof lock function - to activate or deactivate it press the start button for about 4 seconds during a cycle - check page 32 of the user manual for a more detailed description. Hope this helps - please ask again if not :)
Apr 15, 2007 | Bosch Exxcel WFX 145S Front Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
