Question about Microsoft Xbox 360 Console
E74 and 4 red ring Xbox 360
My sons console button has a red light instead of green and read error 74
i suspect it`s been droped any hope of us fixing it ??????????? :>
  • 1 more comment
  • Anonymous May 25, 2008
    it has 1 red ring light and says e74
  • ocampovicent Jul 13, 2008
    a red light appears instead of a green light
  • Maype Oct 05, 2008
    when i turn on my xbox it comes up with one red light rather than 4 green ones and when i tun it on it says e 74 how can i fix it.and the red light is on the third player bar.
    Sergeant:
    Champion:
  • 241 Answers
The a/v card is faulty, there is a chip called " ana or hana " and that goes bad.
the best solution is either to send it to microsoft " they will charge you around $ 100 - $ 150.- " to fix it, or to find the chip and replace it.
there is hope though try another a/v cabel, borrow one or something, your cable may be damaged. if the new cable doesn't work then " 100 % sure is the chip " is very common problem.
i have one with that issues and bought another 360 " broken " and i am going to try to switch a/v cards.
Posted on May 25, 2008
  • francisco navarro
    francisco navarro May 26, 2008
    yes,that's what i mean, that code call for a/v problem....try replacing the gray cord, if that doesn't fix it then you have a bad a/v circuit board.
    E74 = A/V not detected or fault detected
Ive got the same problem hope it works out for you...
Posted on Apr 16, 2008
My console freezes and a red light glows around the power button instead of it glowing green like normal
You have the infamous red ring of death.
http://en.wikipedia.org/wiki/Xbox_360_technical_problems#.22General_Hardware_Failure.22_errors
There are many ways to repair this. Just Google "Red ring of death repair" and you'll find many articles and videos explaining how to do it. It'll be tough, but it's a doable repair. Hope this helps!
Apr 13, 2011 | Microsoft Xbox 360 Console
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
My xbox 360 has 3 red lights and is not working
Turn your Xbox off for like 3 hours..... Turn it back on, if ERROR 74 shows up then you have RROD "Red Ring Of Death".... https://myservice.xbox.com/en-us/Pages/Welcome.aspx If you haven't had it for three years yet, you can send it in to Microsoft and they will fix it free of charge... Next time, try to use the Xbox less.... The more you use it the more it is prone to overheating melting a motherboard chip thus causing error 74
Jan 08, 2011 | Microsoft Xbox 360 Console
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
Jun 30, 2009 | Microsoft Xbox 360 Console
READING SYSTEM ERROR E 74.
THIS IS LINKED with the £ red lights, or the red ring of death, so as long as its not 3 years old, Microsoft will repair it in the 3 year extended warranty, so head to xbox.com/support and get a repair, should take about 1-2 weeks.
Jun 07, 2009 | Microsoft Xbox 360 Console
Red light instead of green
http://www.squidoo.com/xbox-troubleshooting-red-ring-of-death-fix
go here and scroll down the page to find some guidance on how to troubleshoot your problem
I hope this helps
Nov 17, 2008 | Microsoft Xbox 360 Console
E74
The E-74 error is also due to overheating and the RROD fix also cures this fault, hope that helps :)
Nov 11, 2008 | Microsoft Xbox 360 Console
X box 360
18004MYXBOX, this is the Xbox support center and they will either know exactly what to do or will have you ship it off to get it fixed(its usually under warranty and free). I had a similar problem where my xbox would work fine but just wouldnt read any of my disc no matter what is was.
Oct 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
177 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
