Question about Trendware TEW-430APB 802.11g/b (TEW430APB) Wireless Access Point
Using a wireless bridge for Dreambox
Using Wireless bridge.....I am trying to connect a wireless bridge to my Dreambox. How do I input my wireless settings so it can talk to the wireless network? Thanks
  • Anonymous May 20, 2009
    do i need a dish to work this dream box
I dont think it has wirless on it mate but j tag it
Posted on Apr 19, 2008
I have tried several times to download a tv programme on catch up TV.The programme comes up as 'downloading' but subsequently it comes up as 'failed' Any suggestions?
It is best to say where you are so a local expert can reply. Generic reasons for this may be
- your internet link is too slow
- the server at the other end is overloaded
- there is some type of local login required from you
- there is insufficient space on your device to cache large amounts of video data
Oct 28, 2013 | Patazon Wifi Bridge Dongle Wireless...
Can I use one wireless router to connect to my primary wireless router?
You wouldn't use a wireless router for the second device -- you would use a wireless bridge device. Most Wireless Access Points can be configured to be wireless bridge devices or you may be able to find a dedicated wireless bridge. Unfortunately, these devices usually have just one Ethernet port. That will mean that you'll need to buy an Ethernet switch in addition to the device that you're going to be using as a wireless bridge. This will add to your cost and make it so there is no real cost savings by using the Wireless Bridge + Ethernet switch combination.
If you can find a wireless bridge unit that has more than one Ethernet port, then you may be in business.
Using a second wireless router will not work unless the device has the ability to be configured to be a wireless bridge. Such routers are usually more expensive than your typical router, but you might get lucky and find one at a good price.
Good Luck
Feb 09, 2012 | Linksys Computers & Internet
Connect to wifi on blackberry and ps3
It is just be a matter of synching the blue tooth system of the blackberry to that of the PS3. Assuming the PS3 is not currently connected to the web or connected to a modem, you should be able to search for the PS3 by using the Bluetooth search tool in the Blackberry setup menus. Then for headsets,set those up through the PS3 by turning on the head sets, and then using the Blue tooth set up utility of the PS3 to search for the head sets.
Otherwise If you do not have Wifi active currently and don't have good cellular coverage in your area, you can use a Wifi Bridge Dongle (connector cable) like this one, there are others available too.
http://www.espow.com/wholesale-wifi-bridge-dongle-wireless-for-dreambox-xbox-ps3.html
to connect the PS3 to your home computer and use it as the hub assuming you ahve it connected to DSL or broadband. headsets would set up the same way.
Jan 04, 2012 | Sony Playstation 3 (PS3) Console
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
Connect D-Link DWL-G700AP to dreambox decoder
you can connect to your box via FTP via a crossover cable. If you can’t, you might want to read up on that before attempting this.
Now, what we’ll need is…
Ethernet cable (crossover or patch)
Router
Modem
We’ll also assume that you have a router (wireless or not) and that your modem is connected to the ‘Internet’ or ‘WAN’ port.
If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don’t need to change any settings on your router or PC.
Over to the dreambox. Navigate to the networking page on your dreambox.
Setup -> Expert Setup -> Communication Setup
Dec 09, 2009 | D-Link DWL-G700AP (S2984376) 802.11g/b...
I have two Dell 2350 Wireless Routers trying to bridge or repeat
The first router must the root AP and the second should be set to Wireless Repeater. Follow the steps on how to resolve this setup.
1. Get the Wireless MAC Address of the main router. The router has two MAC addresses, one is wired and 1 is wireless. To determine the wireless MAC address, go to Status page of the router, there's a sub tab there for wireless and you'll see the Wireless MAC Address. Take note of it.
2. Access the setup page of the 2nd router. Change the LAN IP address to 192.168.0.2 then save. Power cycle it by just turning it off for 10 seconds then turn it back on. You can now change it to Wireless Repeater and there's an option for you to type the Wireless MAC address of the main AP. Make sure all wireless settings are the same on both routers like SSID, Channel and Encryption Key. Save your changes after that.
3. From your computer, try to ping the 2nd AP which is 192.168.0.2. If it replied back, you're all set.
Good Luck!
Jul 25, 2009 | Computers & Internet
I have an old Linksys WRT54G v1.1 wireless router - trying to connect to my new DSL line using a motoral modem, to my Dell laptop running XP. help!!!
Is the motorola currently surfing and are you trying to add the linksys to it? If so you will need to go into the motorola and set it to bridge connection under connection type found in the expert mode of the modem. Then you will add the linksys and input the username and password in the pppoe connection type. Once the info is save click on the status tab and click connect. Hope this helps
May 16, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
Dropped connection
Step 1:
Connect the Wireless-G Music Bridge to your router using an Ethernet cable. For instructions, click here.
Step 2:
Access the Wireless-G Music Bridge’s web-based setup page. For instructions, click here.
Step 3:
When the Wireless-G Music Bridge’s setup page appears, scroll down to the Wireless section and look for Wireless Mode and select Infrastructure.
Step 4:
Look for the Wireless Network Name (SSID) field, enter the wireless network’s SSID.
If this doesn't work let me know
Aloha
Bob
Dec 13, 2007 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Trendware TEW-430APB 802.11g/b (TEW430APB) Wireless Access Point Logo
1,836 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
