Question about Sony XM-754HX Car Audio Amplifier
Wired bass control knob
Hello, I was wondering if the wired bass control knobs are universal. I mean if you did'nt have a bass control knob, could you use any ole one that you can buy from ebay, or some other source. I am not sure about this. all the wired bass control knobs that I have seen all seam to have the same telephone type wireing.
  • 631 Answers
Not all controls are the same. Manufacturers use various schemes to control the level of the audio. If you use a control that's wired improperly, you risk damaging your amp.
Posted on Apr 17, 2008
How to make a remote bass knob for a hifonics crossover
Bass knobs are just Rheostat "switches" run to a 2.5mm jack.
They are all essentially universal, and you can find them for very cheap, typically around what it would cost to build one.
Mar 17, 2015 | Hifonics Car Audio & Video
My ibanez sr700 bass guitar's volume knob is very
To remove the knob, there should be a small hex key or allen screw on the side of the knob. Just loosen the screw. You don't have to remove it.
To tighten the nut properly, you may have to remove the back panel of the bass and hold the potentiometer from the other side. If allowed to turn too much, it could mess up the wiring.
Feb 26, 2013 | Music
I dont have the blast port wire and it wont play.where can i find the wire?
  • BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
  • Here is the manufacturer's accessory page to the remote: http://www.kicker.com/zxrc
    Here is one on eBay: http://cgi.ebay.com/KICKER-2010-10-ZXRC-AMP-AMPLIFIER-REMOTE-BASS-CONTROL-/360328112100?pt=LH_DefaultDomain_0&hash=item53e53aa7e4
    And here is a note from Kicker on how to make a control yourself for strapping multiple amps together: I have two or more Kicker SX or KX subwoofer amplifiers. I don' t want to use all those separate bass level controls. Is there a way to make them all work with a single Kicker control knob?
    Yes. You can visit your local Radio Shack or home improvement store and purchase an RJ-11 modular adapter. You then plug the sub level cables from the individual amplifiers into the adapter. Then run a cable from the adapter to a single Kicker remote knob. All amps will now work with a single knob.
    Dec 28, 2010 | Kicker SX400.2 Car Audio Amplifier
    Does anyone know how to make a bass knob remote out of phone line? What the color code? I have 4 different color wire here but i don't know what to do to make a bass knob remote.
    It is NOT clear what you are trying to do... HOWEVER if you are attempting to extend a bass potentiometer remotely, you CANNOT use the four wire flat telephone line as it is unshielded and you will pick up hum.
    Dec 04, 2010 | Marshall Amplification Marshall IBS Bass...
    MY KNOBS ON THE RIGHT OF THE REACEIVER BROKE OFF.... 1 FOR BASS AND TREBBLE ONE FOR IMPUT SELECTION HOW CAN I GET IT FIXED
    that depends if the knobs or the shafts are broken.the knobs are easily replaced as they just pull off. the controls is a different problem as they are soldered into the pc board.the input selector switch will have alot of pins and the bass and treble 6 pins each.the front panel has to be removed,the lock nuts taken out and sometimes the input selector has a small pc board that is wired to the main pc on a connector,and the replacement comes with the pc board.the parts can be got from sony parts or an authorized repair depot.unless you are really good with electronics,it is best left to a pro to fix,the power supply in that unit runs on over 100 volts dc
    Apr 26, 2010 | Sony STR-DG910
    The bass go in and out ,the sub bass knob is loose, can i fix it
    the bass nob must have worn out, that's why it cannot stay firm when you press it in.
    Get something tiny like a pin, press the bass knob in, and at the same time fix in the tiny object by the side of the knob, to hold the bass knob firm, so that it will not pop out when you let go off it.
    Take care.
    Mar 29, 2010 | Hifonics BX1500D Car Audio Amplifier
    I need a bass knob for my crunch amp
    i need an bass knob for an planet audio rxd2400
    Mar 01, 2009 | Hifonics TX1505D Car Audio Amplifier
    Bass control stopped working
    on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
    Aug 10, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
    Wired remote bass control knobs
    I'm wanting to know the same thing... But be careful on the pin out of the control you get.
    I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
    I have tools to crimp an end... Just can't figure out the color pin out.
    Apr 16, 2008 | Car Audio & Video
    Car Audio & Video Logo
    308 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
