Question about Canon Pixma MP500 All-In-One InkJet Printer
Stripe on back of paper for Canon printer
DId you ever find a solution? My pixma MP500 does the same. Only started about a month ago, printer is about a year old.
  • 4 more comments
  • BooBoo79 May 15, 2008
    Same thing after about a year and a half. Replaced the print head, no better. If we print 3-5 pages, it'll clear up and print clean until the printer rests for a while, then the stripe returns. Sometimes it's a broken stripe, sometimes it's a fat stripe. We're about to buy an HP for the home office but the Pixma will soldier on in the basement workshop.
  • Anonymous May 18, 2008
    I have the same problem with my mp500. canon rep says I must be using off brand ink but I have not. they say I need to have it repaired - not worth it
  • Gisco May 20, 2008
    Has anyone come up with a solution to the black ink stripe on the back of the paper. I use only cannon ink and tech support says to send it in for repair. I don't think it is worth it. My model is MP830
  • pcotcamp Jan 03, 2009
    Exact same problem. Did anyone ever find a solution?
  • etarney Jan 07, 2009
    See my comment April 2008 - I just had same thing happen again today. I have been printing letters - printed about 150 in batches of 20 or so over the past 2 days, no problems. Suddenly tonight started seeing teh *&#^%@$ stripe again. Happened near the end of a PGBK cartridge, so it was not a faulty cartridge. It continued after I replaced it (with true blue Canon cartridge as always) so it was not the old cartridge at all. Was in the middle of a paper tray, so not the paper. Just deep-cleaned PGBK noxzzle & bottom of paper try a couple times each. Seems to have worked for now. @%$#@%^!@^%#!@#*&!%*(%!!!!!!! Never the less, for all I have used this printer, I have had only these two incidents in about 3 years, otherwise I love the printer. If it were only a fax machine, it would be perfect, but it makes great scans to be emailed, next best thing.
    *($%$%!$$&*%^@&$**@(!()@!@ -- see post below from 5 minutes ago --- just now it printed 18 pages fine after the cleaning, and then the stripe suddenly returned on the 19th page, fresh as ever, and then faded away over the next 3 or 4 pages. I am beginning to wonder if the "MP" in the model name stands for "maybe poltergeist"?!?!?!
This is how I finally resolved the issue. Deep cleaning on PGBK head several times and bottom plate cleaning several times. This is done thru maintenance tab.
Posted on Jun 04, 2008
Reset canon printer MP500
Call canon tech support for any of issue in printer you can them directly here is the number (877-690-9305)
Jul 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
When printing a black stripe of ink is deposited on the underside (wrong side) of the paper. Any ideas for fixing?
wipe out the part under the printer head. check for inks that may have come in contact there accidentally. usually during paper jams. you may use a kleenex. don't use a paper towel as it is too rough. Anything soft would do.
Jun 19, 2010 | Canon Pixma MP500 All-In-One InkJet...
Error 6500 on a Canon MP500
choy ada yg tahu printer canon pixma mp500 error code 6500 g y? please help me
May 12, 2010 | Canon Pixma MP500 All-In-One InkJet...
Re: Canon Pima MP500 Printer.Despite running cleaning settings for print head and rollers ectc,I am still getting a 1cm wide line of black ink through the length of the reverse side of printed pages....
On back side of printed paper?
It means that you have an ink in paper path, i would ques on registration roller (long black roller which you can see when you open the printer cover).
Try to print 20-30 white sheets or similar to get rid of stripes
Jan 18, 2010 | Canon Pixma MP500 All-In-One InkJet...
Pixma error code 6A00
Dear luis,
Your printer has paper feed related error. There are 2 possibilities of this errror: Auto sheet feeder or logic board faulty. Then you need to replace these parts.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Printer PIXMA MP500
Check in the printer driver properties window on the computer. It sounds like the Paper Source is set to "Auto Sheet Feeder". You need to change this setting to "Paper Feed Switch" so that you can select the paper source from the printer itself.
Jul 24, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printing
when you have this problem of your printer disconnect it remove ink catridge colector and clean .
Feb 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
242 people viewed this question
old marine
old marine
