Question about Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Problem
I have the same problem with my set "chirping sound and the power light stays on but no picture or sound". I had followed your instruction disconnecting CRT sockets with the same result.
Please give some more advises to find the short on the horizontal output.
Thank in advance,
ND
  • 149 Answers
If you have chirping sound .. check your horizontal out transistor that may be one cause there are seven or nine green lights around power supply see if all came on if not call me 520-248-4242 or leave message
Posted on Apr 17, 2008
CHIRPING SAMSUNG PROJECTION TV
Chirping is set is in shutdown---most likely in High voltage area of set.
Jun 11, 2012 | Samsung Televison & Video
Rca P52927 TV will not power up and chirps when plugged in. Any help?
while playing ps3 on the tv first a chirping sound, then a loud pop then the set cut off. After the set cut off the red timer light stays on.
Jan 23, 2010 | RCA Televison & Video
Magnavox model 51mp6100/37, the power light comes on but no picture or sound. a strange niose comes from the back panel
If its a chirping sound the convergence chips are shorted. I learned this the hard way.
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 18, 2009 | Philips Televison & Video
No Picture or Sound and chirping from rear
Most likely there are defective capacitors in the power supply. The chirping you are hearing is the attemt to fire up the supply. The cold may have been enough to cause the caps that were on the verge of failing to completely fail. This should be a simple repair for any shop. If you wish to attempt the repair yourself, let me know and I'll try to get you mode details on the likely defective parts.
Dan
Feb 13, 2009 | Philips 51PW9363 51" Rear Projection...
Philips 55PP9352 Rear Projection, no picture or sound
Mine had the same problem, and it turned out to be the power board.
Dec 20, 2008 | Philips 55PW9363 55" Rear Projection...
Dead set been throught the obvious but still won"t turn on
did you try disconnecting CRT sockets or picture tube anode ? if do so disconnect sound board I had same problem if still have the problem I may hel you e-mail me
Feb 26, 2008 | Hitachi 43FDX01B TV
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Hitachi 43FDX01B TV Logo
100 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
