Look on the side of the saw, where the blade/chain enter the plastic case. You will see a nut in there. Loosen the nut, then push the bar backwards towards the saw. It will put slack in the chain and you can pull it off the sprocket/clutch in there. (Use a screwdriver if you can't reach in there with your fingers) and wear gloves... even a dull chain can gouge you if your fingers slip. Once it's off the sprocket, then just pull the whole chain off. To install the new one, put it around the sprocket, make sure the chain guides are lined up with the groove in the bar and on the tip of the bar, then pull out on the bar (away from saw) to take the slack out of the chain. Holding the bar firmly to keep the tension on the chain, tighten the nut again. Bada-bing you're done. Should only take about 5 minutes to change it.
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-cover-and.html
How to Remove Timing Chain and Gears on Toyota Previa?
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-and-gears-on.html
Ford Mondeo ST220 camshaft Timing specifications?
http://technoanswers.blogspot.in/2012/02/ford-mondeo-st220-camshaft-timing.html
------------Replacing Timing Chain Cover For 2009
Ford?
http://repairhelpcenter.blogspot.in/2012/03/replacing-timing-chain-cover-ford-2009.html
Timing Chains & Front Cover Removal on
2008 Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/timing-chains-front-cover-removal-on.html
----------How to Replace Timing Chain Cover, Chain,
Sprockets, & Seal On Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-cover-chain.html
---------How to Replace Timing Chain &
Sprockets on Ford Windstar?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
---------Timing Chain &
Sprockets Replacing on Ford, Mercury and Lincoln?
http://fordrepairhelp.blogspot.in/2012/03/timing-chain-sprockets-replacing-on.html
Chain & Sprockets on Ford Edge and Lincoln
MKX?
http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
------How To Replace Timing Chain, Sprockets
& Front Cover on Ford Expedition and Lincoln Navigator?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets_356.html
---------Timing Chain,
Sprockets, Front Cover & Seal removal for Ford Mustang?
http://schematicsdiagram.blogspot.in/2012/03/timing-chain-sprockets-front-cover-seal.html
Chain on Buick LaCrosse?
http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-on-buick.html
---------These details will help.For more help keep updated.Thanks.
