I need the circuit board that the cross fader connects to. It is for the Technics SH-DJ1200 mixer. I have fitted a new cross fader and I am encountering bleeding. If the cross fader is over to the left and i am listening to a tune on the right deck in my headphone and the right volume fader is up the tune is bleeding through. My self and my engineer believe it must be the circuit board.
  • 4,234 Answers
I have found a part number for a cross fader kit although this might only be the faders. Can you get the number off of hte board itself and post it here? I'll research this a bit more.
Dan
Posted on Apr 16, 2008
Both Technics SL1210 mkII's loud hum and almost no sound...
You seem to have some feedback hum from somewhere. I would think it might be caused by a faulty connection somewhere.
Mar 12, 2017 | Technics Audio Players & Recorders
I have a Behringer eurorack ub1002 mixer. how can i open it up to fit a new socket on the face of the desk. I seem to have unscrews all the screws
One has to remove all the knobs, including the faders. There are MANY screws through the panel AND all the 1/4 inch jack hardware has to be removed. Remove EVERYTHING else BEFORE removing the small screws... It is a LOT of work, although this mixer is small compared to some! Be careful to NOT scratch the circuit board as Behringer uses very small/narrow circut traces that are easily damaged. Make sure you have the EXACT same socket so it not only lines up with the holes but is the right height from the circuit board, Temporarily mount the socket along with the mating ones before soldering the pins so it is in perfect alignment to fit the hole in the panel.
Jan 25, 2011 | Behringer Xenyx 1002fx 10-input Mixer W/...
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Technics headphones RP-DJ1200
You can buy replacement plugs and solder them on. Make sure you take the old one to the store when you purchase the replacement. The next thing you need to do is figure out which wire goes to which part on the plug. You can us a volt ohm meter to test the old plug and see which color of wire or which color of wire insulation matches to which part of the plug. You can also try taking the foam pad off the left earpiece and look to see if you can get the speaker plate off the earpiece. Once off you can look to see which color goes wher. There will be another wire there that connects the right earpiece to the left one. Make sure you unscrew the shield from the plug and put it over the cord facing the correct direction before you solder the plug to the wiring. Screw it to the plug after. Hope this helps.
Jul 10, 2009 | Technics RP-DJ1200 Professional Headphones
Pitch slider
usually, when you buy the pitch fader itself, then it comes with the circuit board. Ring up panasonic or a distributor and maybe they stock them, but im not sure why you need just a circuit board...and if u bought a pitch and it came without one, then just give a ring around...at least someone will stock it
Jun 01, 2009 | Technics SL-1210 Turntable
Turntable Crackling
sounds to me like your fader has popped! lube contact spray will not solve the problem, it will only clear it up for a few passes if any! PCV faders have covers inside which stop any lube getting right on the contacts! but in my experience as a scratch dj for 11 years is that contact spray only make the problem worse over time! best shot from here is to replace the fader, or get a mixer with optical/contactless fader i suggest a mixer with the 'eternal' fader i.e. ecler 360/80hak. hope this helps
Feb 03, 2009 | Technics SL-1210 Turntable
Dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
Nov 09, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
119 people viewed this question
 Grubhead
Grubhead
