Question about Lexmark Wheelwriter 15 Series II Typewriter
Ibm Selectric III typewriter
The light to the typewriter goes on, but there is no "hum" when turned on, and you cannot type. I've unplugged the machine, and checked to see if anything fell inside. I don't know how to remove the cover to check for problems. what to do? thanks
  • Anonymous Apr 21, 2008
    wheelwriter 15 lights go on but nothing further happens
  • tholloway Jul 17, 2008
    We have the same IBM Selectric II typewriter. Our problem is even though there is power and we have the "hum", our keyboard is locked and we cannot depress any of the keys. When we touch the shift key, the previous keys we depressed print out eg. (touch q nothing happens, touch shift we get q-) go figure.
    Not sure how to fix, have read the manual, it doesn't offer any trouble shooting.
    T in Vancouver
To Tholloway;
The problem is in the shift clutch. Unless you know how to remove the upper case there isn't a lot you can do.
DickyO
Posted on Jul 18, 2008
  • Lexmark Master
  • 3,594 Answers
Could be a lot of things. Most likely is a motor belt. It's not likely an untrained person could change it. To remove the case there are latches on the rt. & l. sides, levers on the insides of case move themto the front and remove case.
DickyO
Posted on Apr 16, 2008
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
How can I determine whether my typewriter is a Selectric II or III?
The video shows the models C, Selectric I, and Selectric II.
If your typewriter doesn't compare to any of these in the video it is most likely a Selectric III.
This will also help:
The Selectric III featured a 96-character element vs. the previous 88-character element. IBM's series of "Electronic Typewriters" used this same 96-character element. The 96-character elements can be identified by yellow printing on the top plastic surface and the legend "96," which always appears along with the font name and pitch. The 96- and 88-character elements are mechanically incompatible with each other (they won't fit on each other's machines) and 96-character elements were not available in as many fonts as the older 88-character types.
Jul 09, 2013 | Office Equipment & Supplies
IBM Correcting Selectric III broken!
Hi:
The cycle clutch has dried out and is causing the delay and lockup. These machines are to complex mechanically to repair on your own. I would try to seek out someone who still repairs these and have them do a general clean and lubrication.
Jul 17, 2012 | IBM Correcting Selectric III Electric...
Go to lexmark.com and click your way to publications there you will find a manual with pictures and instructions on the ribbon.
DickyO
Mar 14, 2010 | IBM Office Equipment & Supplies
IBM SELECTRIC III, won't print
try turning the metal shaft that the carrier is on. turn it towards the back of the machine.
Apr 10, 2009 | IBM Wheelwriter 30 Typewriter
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
IBM Selectric III - ribbon won't turn
Make sure the ribbon cartridge lever is closed and that the ribbon is on the outside of the shock wire (where the ribbon exits the left side of the cartridge)
Jan 20, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 15 Series II Typewriter Logo
637 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
