FixYa.com
Tags:
Washing Machines
Generic problem for all Washing Machines
Agitator movement is weak
posted by fowski on Apr 16, 2008
agitator movement is weak
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 16, 2008
Not Rated (0)
dauphine
Rank:Guru Guru
Rating: 87%, 119 votes
Several possible causes:
  1. Basket overloaded
  2. Belt loose
  3. Bearing damaged
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Energy Star 3.7 IEC Cu. Ft. King-size Capacity Frontload Washer with Stainless Steel Basket, WB... GE WSM2700W/WW/AA Top Load Stacked Washer / Dryer GE WDSR2080D Top Load Washer Bosch Axxis WFL 2060 Front Load Washer GE WBVH6240F Front Load Washer Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530 1UC / SUC / CUC / WFMC530CUC - Champagne Du Bosch Axxis+ WFR 2460 Front Load Washer
Can you Help with these Washing Machines problems?
Washing Machines
godrej auto washing machine
the machine takes in water,... Answer This...
Washing Machines
Washer won't drain or spin out...
My Whirlpool Washer LXR7244JQ1... Answer This...
Washing Machines
kenmore series 80 drips water
kenmore series 80 drips water... Answer This...
Washing Machines
The washer will only work
The washer will only work in... Answer This...
Washing Machines
Basin will not retain water.
Basin will not retain water. ... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
