Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Major issues For 3 weeks the internet connection has been unstable. I phoned Belkin and because the old router re-set button was broken they replaced it with a new N1 router. After installing the N1 and then subsequently re-installing the USB software the same problem exists. Connection is unstable. I had my provider here today to check the modem and he was perplexed also! After 2 hours he gave me a new modem and basically said maybe there is a compatability problem with the modem and the N1 router. I spent 6 hours on and off the phone with the Belkin helpdesk and they couldn'[t figure it out so they escalated my call to the higher ups at Belkin (in Australi) I am waiting on a call from them now, but thought someone else may have some answers! Good luck and thanks!
  • why_14 May 11, 2010
    What version is your Belkin N1 router? The version number can be found on the bottom of the unit (ie 1000, 2000, 3011, etc).
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now.
Hope this helps, and good luck!
Posted on Sep 03, 2008
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
Mar 07, 2014 | Belkin N Wireless Modem-Router F5D8633au4A
I have lost the code for my belkin router & my reset button is broken! Any suggestions?
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK "
Dec 10, 2010 | Belkin (F5D8231-4) Wireless Router...
Netgear WG111v3 USB adapter not connecting desktop to Belkin router. this notebook is working OK. The adapter has been working OK for about 3 weeks.
Try to download the newest driver from belkin that matches the version and model. Uninstall the old driver and install the new one. This should fix the issue. you will need a pc that is connected / working to the internet to get this done.
Jan 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Connection
Update the firmware on the router to the latest version available on Belkin's website. Do this over a wired connection, NOT wireless. Also, make sure that your modem is not the issue.
Apr 10, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin/problem with connection
you tried turning it off and then back on the router, sometimes they just need to reacquire the ip
Dec 22, 2007 | Belkin (F5D7633UK4A) Wireless Router
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
325 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
