Question about Jabra BT620 BLUETOOTH STEREO HANDS-FREE HEADSET Headset
Devices are losing signal to the BT620
Any ideas? Perhaps I've over used them?
  • Anonymous Apr 16, 2008
    I HAVE NO IDEA HOW RESOLV THE PROBLEM
Geez mate, you are so smart.........
Posted on Aug 14, 2008
Tv loses sound after around 45minutes of being swiched on
there may be problem in your amplifier or the mute signal or the input signal from processor or speakers, First you have to check the audio output from the processor by using another external amplifier... connect it to the correct audio out pin of processor( these are R,L audio written in pcb near the processor lead that carry) if there is sound moreover than 45 minute....... replace the external amplifier and connect it to its own amplifier.... disconnect the own cabin speakers and connect another sp. and check... if there is sound break after45 minute.... replace the amplifier ic(may beTDA7297) if there is still have the problem, check the amplifier circuite suitable for your ic and dissconnect the mute connection from processor and make a connection to the +ve or ground follows as the circuit(means give external mute signal to amplifier dont from processor)......
Nov 09, 2013 | Televison & Video
Internet connection lost every 30 minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
May 22, 2012 | D-Link Xtreme N DIR-655 Wireless Router
I've got a pair of Garmin Rino 110 that we use when outdoors. Recently, with full batteries and clear skies in the desert, not surrounded by trees, mountains, buildings, etc... both of the Rino 110s...
  • That RINO should have no issues picking up satellite signals in the conditions you were in. If you were inside a building I may buy it but not in an open desert. Sounds like they are feeding you a line to me. I might try to get my money back on that one. One thing is for sure, you were in about the best conditions for using that unit. If it failed you then, it will more than likely fail you when your life may rely on it. It would seem that a different GPS/GMRS unit will be necessary to give you that security.
Regards, Tony
May 10, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
Losing gps signal very often
If you are finding that you lose GPS signal in open areas the receiver chip may be dead, if your unit has an external antenna port you could try that it would bypass the broken receiver and allow you to use the unit.
Hope this helps!
Dec 09, 2010 | Insignia NSNAV01 GPS Receiver
M205 Logitech wirelessmouse works in my laptop,
Perhaps your laptop can receive the signal from your wireless mouse (by design) whereas your desktop cannot. Your desktop may need an expansion card to communicate with wireless devices, such as a mouse or other such device.
Nov 22, 2009 | Logitech Cordless Mouse
57HX81 Toshiba. picture gets squiggly on dvd input
Perhaps 2 things. Does TV get a picture without DVD connected? If so I would bet you have a faulty connection in your signal board where the in jacks are at the back of the TV . Check to make sure cable from DVD are not bad, I have used cables before and got a false positive. Try turning and spinning the jacks once you have a picture.Make sure your signal board is firmly pressed into its slot on the signal board chassis. Thats it for now. Good luck.
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
I lose wireless connection
Fair enough you may have a 100% signal from your router but perhaps the router is not getting any feed from the exchange, have you tried plugging your LAN cable into the router to see if you can connect to the net ? if you can then i suggest you call your ISP
Dec 14, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Jabra BT620 Microphone dose not work with Soft Phone on My PC
Well, I got the same problem the days before, and after some trying, I've solved.
I'm using the Toshiba bluetooth adapter, too. You see, when you want to make a new connection with your bluetooth device, you may either use the Express Mode or the Custom Mode. Go with the Custom Mode, then, there appears the Jabra BT620. After input the 0000 code, you may select the services from 3 options. There, you can find the headset or hands-free option.
Go with that, than you may have your Jabra BT620 as a microphone!
Sep 09, 2008 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Sony Tuner KV-20TS27 loses signal
Either that of your tuner block is acting up. Most Sonys of this production year uses a tuner block that requires 33VDC tuning supply. It has been known for this zener to fail or the capacitor parallel to it. At times, it could just be the tuner block itself.
Should you venture a DIY, it would be to your advantage to have access to a service manual or at the very least a schematic diagram with voltage readings.. It further requires familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Should you be uncomfortable going this route, then perhaps your best bet would be to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Televison & Video
RE:BT320/BT620
Hi Leba,
Try downloading these lastest drivers, and see if that helps. Drivers off of CD can be really old.
http://www.broadcom.com/products/bluetooth_update.php
Let me know it they work, please, since I just order two of these units to update my older ones.
Good Luck!
Jan 07, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
Jabra BT620 BLUETOOTH STEREO HANDS-FREE HEADSET Headset Logo
162 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
