Question about Haier PDVD10 Portable DVD Player
I have a Haier PDVD10 Portable DVD player that has no brightness on the screen.
You can just make out images on the screen. Is the LCD display Bad and the unit a thow away or is it something that can be fixed?
Thanks,
Chuck D.
  • Anonymous Nov 15, 2008
    have a Haier PDVD7 Portable DVD player. The color suddenly is oversaturated and the images pixelated. Is there a solution?
    I have a Haier PDVD7 Portable DVD player that suddenly has oversaturated colors and pixelated images. Can anyone help?
    John B.
chris5563
  • 37 Answers
SOURCE: haier portable DVD player
Any particular model number?
Posted on Nov 07, 2007
  • 10 Answers
SOURCE: need power cords/chargers for Haier portable DVD player
you can get almost any power cord at radio shack either bring in the machine or copy down the proper volts ect. of the machine it will say right where the cord plugs in
Posted on Jan 31, 2009
  • 303 Answers
SOURCE: No cord
click on hyperlink
buy replacement ac power charger adapter for HAIER PDVD7
Posted on Feb 13, 2009
yeroc
  • 397 Answers
SOURCE: Haier portable DVD player will try an load the
Check to make sure exact power volts are meeting units specifications, take a reading at end of power cord
Posted on Dec 02, 2009
Mustgo
  • 2359 Answers
SOURCE: where can i get a replacement batter for my Haier
Haier globe web link here.
Posted on Jul 08, 2010
My INSIGNIA NS-PDVD10 portable DVD player will not power up. Can you help me identify the problem? Will the rechargeable battery go bad in this device?
Of course the battery will go bad , nothing made by man ever lasts forever . it may need to be sent it for replacement of battery .
Oct 16, 2015 | Insignia NS-PDVD10 Portable DVD Player
I NEED A CHARGER FOR MY INSIGNIA
the IS-PDVD10 takes a 12v wall-wart and should be available from any electronics retailer (like Best Buy ;) ).
It will work with a 9v power pack, but there will be issues with image quality and volume since the device is underpowered. This is not recomended.
Hope this helps!
Apr 15, 2010 | Insignia IS-PDVD10 Portable DVD Player
No picture on dvd player but can hear sound
Usually this is a bad inverter. The best way to check this is to hold the unit up to a very bright light and see if there is a ghost of am image visible and moving, just not bright enough to be seen properly. This means that the display is working, but the flourescent display behind it is not being powered properly, and most LCD displays require a little inverter board to convert the native DC power to AC to light the backlight. inverter boards are cheap if you can find the proper one for your unit. Unfortunately some units have the inverter board integrated into the motherboard of the player, though that is rare. It should be a separate (and thus replacable) component. Good luck!
Dec 01, 2009 | Toshiba SD-P1400 Portable DVD Player
I have Insignia PDVD10 portable DVD player. So
Press remote button audio track. That solve my problem.
Jul 04, 2009 | Insignia NS-PDVD10 Portable DVD Player
Portable dvd player insignia ns-pdvd10 screen problem
Check the screen switch on the right top side where the door closes there is a little circle and the release switch usually gets jammed (this is a common defect) you will need a small thin flat head screwdriver to pry out the switch.
Jun 18, 2008 | Insignia IS-PDVD10 Portable DVD Player
Fixing the picture on the Insignia IS-PDVD10 10.2" Portable DVD Player
The player is in 4:3 mode (Standard TV mode). There is a button on the deck of the player called MONITOR that will toggle between 4:3 and 16:9 modes.
Press this button.
You can also check to screen geometry in the SETUP menu and make sure it's set to WIDESCREEN.
Jan 05, 2008 | Insignia IS-PDVD10 Portable DVD Player
INSIGNIA PORTABLE DVD
Use the A/V outs to the composite cable and connect to your Westinghouse A/V jacks.
On the Insignia player, press the Source button until you see A/V OUT on the insignia players screen.
Set your Westinghouse to the A/V input port you have connected the Insignia player to and VIOLA...you should have picture and sound.
Nov 11, 2007 | Insignia IS-PDVD10 Portable DVD Player
Rolling White Screen
Sounds like your inverter board has failed.
Yes, it is an expensive fix. You can try asking Best Buy if they can repair the unit if it is still under warranty, or what it will cost to have it repaired by the Insignia people.
If the player still works, you can try using it as a set-top unit and connect it to another monitor through the A/V outs.
Oct 01, 2007 | Insignia IS-PDVD10 Portable DVD Player
Display light is dark
I have seen this problem before this is caused by a failure of the backlight which provides illumination for the LCD screen. You may also want to check the inverter also since it fails often and interacts with the backlight.
Sep 04, 2007 | Shinco SDP-1750 Portable DVD Player
Haier PDVD10 Portable DVD Player Logo
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
