Question about Philips CDR775 2-Disc CD Recorder
OPC Error All of a sudden whenever I put a CD-R disc into the burner to record, I get this warning: OPC Error. What is that and is it worth fixing?
    Brigadier General:
  • 8,546 Answers
It implies a media Optical Power Calibration problem (google it). Did you recently start using a different type or brand of disc?
Posted on Jun 28, 2010
Recording
The No OPC message means that the unit can't record. The laser power calibration for the burner failed the internal test with that disc. Was the disc a blank disc? Make sure that you use a clean CD-R or unfinalized CD-RW. Try a different lot or brand of CD-Rs or CD-RWs. If the problem persists, then the laser on the recorder is damaged. If the unit is under warranty, contact Philips. However, based on the date given on the manual, this may not be worth finding a shop to fix the unit. DVD/CD burners for computers are fairly cheap but I'm not sure of the specs for a replacement CD burner for inside this unit.
The manual is available from Philips here: www.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_eng.pdf . The trouble-shooting information is on page 21 (page 23 of the PDF).
I hope this helps.
Jul 11, 2013 | Philips CDR765 2-Disc CD Recorder
What does it mean when says opc error on my tascam cd-rw 900sl?
So far as it looks from other information in the works that this problem is caused by defective media. I always use Taiyo Yuden discs and have had few rejections in over 600 discs. Supermediastore is where disc supplies can be had as well as information on the error rates of different media being produced. The complaints recently were due to a bad batch released of hhb brand discs.
Mar 17, 2013 | Tascam Cd-rw900sl Cd Recorder/player
Every time I put blank cd in recorder side of unit it initializes and then says opc error then disc error...I've had it for about 8yrs
its prbly indicating that the burn laser is no longer functioning especially if the burner has had alot of use prbly still poss to buy parts however could be costly
Oct 12, 2010 | Philips CDR778 2-Disc CD Recorder
Hi.I have CD Recorder Marantz DR6000.After reading and initalizing blank CD-R Audio next on display show OPC ERROR.It,s reading all audio CD,s,oryginal,and CD-R.When I wanna finalized old CD-R,recorded by...
DR-6000 only accepts CD-R audio or CD-R music discs, not the standard CD-R discs. the difference is that the audio and music discs have the OPC formatted differently and they cost a bit more because they include the royalties fee. Standard CD-R discs won't work in this recorder. The correct discs have compact disc "digital audio" logo on them.
Oct 01, 2010 | Marantz DR-6000 CD Player
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
Mar 19, 2010 | Philips CDR870 CD Recorder
THIS IS AN OLD UNIT. SUDDENLY THOUGH IT HAS STOPPED RECORDING.THE MANUAL HAS A NOTE IN IT ABOUT THE OPC LIMIT.1st QUESTION IS WHICH SIDE OF THE RECORDER IS IT TALKING ABOUT BECAUSE IT HAS RECORDED OVER...
Are you actually getting a message regarding OPC?
I'm not sure we can determine which CD drive is exhibiting the problem from what is given, if that's what your Question #1 is about.
Answer #2: If the problem appears at initial calibration of the new disc, try a different (or cleaner) disc. BTW: did you start using a different brand or type of disc in the middle of this?
These links lead to some technical info about what OPC is.
http://www.cdrfaq.org/faq05.html#S5-11
http://www.osta.org/specs/pdf/opc.pdf
Running Optimum Power Control (Running OPC)
A technique used by recorders for monitoring and maintaining the accuracy of all the
mark and land lengths across a CD-R disc.
The CD Recorder does some sample write testing at the beginning of a disc to get a bead on how much laser power it needs to use to make reliable 'ones and nones" on the media. It records the settings in memory. Throughout the recording it monitors surface relectivity and compares it against the test data and in many cases can compensate on the fly for changes.
My read on this is that it may be trying to tell you on any given recording that it has reached or surpassed its effectiveness limit.
Jan 20, 2010 | Aiwa XC-RW700 2-Disc CD Recorder
Disc won't initialize or record, keeps saying no disc or opc erro
I suggest you try cleaning the lens...
If the wrong disc was inserted, say a music disc, there would surely be a message to that effect. If no such message is displayed I would guess the unit is faulty.
Apr 13, 2017 | Philips CDR778 2-Disc CD Recorder
Won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Dec 11, 2007 | Philips CDR785 3-Disc CD Recorder
OPC ERROR
how would I go about fixing the lazer problem with this issue of OPC Error when I push record. Sometimes when I use a lens cleaner, it will records some cds and then the error shows up again. Any help, Thanks
Dec 04, 2007 | Marantz DR-6000 CD Player
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Philips CDR775 2-Disc CD Recorder Logo
1,184 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
