Question about Intel D945GNT Motherboard
3 beep sound coming
When i turn on system 3 beep sound is coming and no display in moniter, then i tried after removing the ram, still the same sound is coming. i cleaned every thing and reconnect again. then also 3 beep sound is coming..
  • 3 more comments
  • rubul Apr 16, 2008
    when i turn on system 3 beep sound is coming and no display in moniter, then i tried after removing the ram, still the same sound is coming. i cleaned every thing and reconnect again. then also 3 beep sound is coming..
  • Anonymous Jun 09, 2008
    I changed the bios memory config to "manual aggressive" and the bios wont reset when I move the jumper and/or pull the battery!
  • tlmcdaniel1 Jun 09, 2008
    In the BIOS I set the memory config to "Manual Aggressive" now three beeps the bios wont reset when I move the jumper or pull the battery???ANY HELP WOULD BE APPRECIATED!
  • Anonymous Nov 18, 2008
    i have the same problem
    After set memory to aggressive... 3 beep after rebot :(
  • mikasa_21 Mar 19, 2009
    I added 1 memory module to run in dual channel mode. Everything worked exept, that the speed was 533 (not 667 as i hoped) so I changed BIOS memory settings to 667. Then it went black and there are 3 beeps and it wont start.
    I dont know how to reset BIOS.
    Any help in getting back default settings?
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Posted on Mar 29, 2009
System on 3 beep sound coming no display what problems
Posted on Sep 08, 2012
    Scholar:
  • 134 Answers
It sounds like you have a bad memory module (refer to http://www.cas411.com/ShowArticle.aspx?ID=54 for a definition of the beeps)
If you have more than one memory stick, try to remove 1 and boot the PC, if the problem is not solved, try to put it back and remove the other one. If it boots, you found the bad culprit. (as discussed in this article : http://www.cas411.com/ShowArticle.aspx?ID=66
Hope this helps
Alex
Posted on Apr 16, 2008
SYSTEM RESTART AGAIN AND AGIN
Posted on May 12, 2008
When I turn on my computer it does not boot up only beeps, what could be wrong?
its a RAM problem. remove the RAM and clean the connectors with a cloth. and re insert RAM.
Dec 17, 2013 | Gateway GT5028 PC Desktop
My laptop makes a continous beep sound and doesnt start till i do it by pressing esc key..?it doesnt start auomatically.
first you replace your ram or check it if on then oky if you have 3 beep then you have display problem you pulg the cable of moniter and press the key fn on change moniter display if display you lcd filament problem its change able if not display then your vga chip heat up so its not have proply solution
Dec 27, 2010 | Compaq Presario 700 470024-192 Notebook
Constant beeping when powered up, no display
If the beeping is constant, check your keyboard for any keys that are stuck in the depressed position.
Jul 07, 2009 | Computers & Internet
Micronpc Clientpro Three beeps on start. moniter does not come on has good video board
Check to be sure RAM is seated correboot up.ctly. If it is replace with known good RAM and re-try
May 20, 2009 | Compaq Deskpro EN PC Desktop
No display, no beep when ram is removed, power led flash for one time and sleeping
some computer do not come with an internal speaker. So then you would hear no beeps. Verify your pc has a internal speaker, either directly on the motherboard, or attached inside the case and plugged in to the motherboard. If you have a speaker, have removed the RAM, and hear nothing when powering on the system, you have a faulty motherboard. It would need to be replaced.
May 11, 2009 | Computers & Internet
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Cant get My dell Dimension b110 to boot no display on moniter!
Which Ram u r using ( DDR, DDR2) , and whats the make of u r PC, as per my understanding Ram is not compatible, is old RAM is still working.
Nov 01, 2008 | Dell Dimension™ B110 PC Desktop
No display
try to clean the RAM with an eraser and then put it back on if still no display remove the video card and clean it with an eraser aswell
hope that helps
Sep 15, 2008 | Jetway (MINIQ 860TWIN) Barebone
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Aug 16, 2008 | Intel D845GVSR Motherboard
No display on moniter but cpu is running
change the RAM(RANDOM ACCESS MEMORY) of your pc.
Dec 12, 2007 | Intel Motherboard
Intel D945GNT Motherboard Logo
749 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
