Question about Samsung SCX 4521F All-In-One Laser Printer
Fax Receiving directly to computer
Is there any way receiving the fax pages direcetly to the computer without printing them on a paper?
I would like receiving my faxs directly to the computer (as was done earlier by the ModemFax).
Which program do I need, and how can I do such (defenitions, etc.)?
Best regards,
  • d_rakshe Jun 07, 2008
    i receive fax but in printer memory it is not print what is the solution
You need WinFax
Posted on May 06, 2008
How do i clear the fax memory? i can only send a few pages at a time without the fax not working and i think it's because the memory is full
most fax machines will show receiving memory left or transmit memory left, if it showing receiving memory full make sure there are no paper jams and there is lots of paper in paper cassettes and it will start to print all the faxes in memory... if its transmit memory, you will need to clear those documents in memory to be sent, probably waiting in que....
Dec 31, 2009 | Brother MFC-8860DN All-In-One Laser...
Seems I can send faxes but have problems with receiving.
That's a driver problem. Uninstall the driver first before reinstalling it.
Apr 09, 2017 | NexxTech NSFTMD1
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
When receiving a fax, it seems that several pages of paper always
you mean you're getting 1 or 2 extra sheets when machine is printing faxes? Feed roller and separation pad that pull paper from the tray are worn.....cleaning will help in the short term.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
Two pages print
Paper could be sticking together or paper is set up for 14 inch and you are running 11 inch paper...
Aug 07, 2008 | Brother IntelliFax-2820 Laser Fax
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
No receiving fax
Make sure there is paper loaded and there is not a jam any where in the machine. Also check you r receiving settings
Jun 05, 2007 | Samsung SF-3100 Plain Paper Inkjet Fax
Samsung SCX 4521F All-In-One Laser Printer Logo
82 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
