Question about D-Link Express EtherNetwork DSS-5+ (NTSWDLDSS5PL)
D-Link Ethernet Switch Lights Flashing and No Internet
Hi, I have a D-Link DSS-5+ Ethernet Switch and a Network Everywhere wireless router. For the past two days, all the lights on my D-Link switch have been flashing rapidly and I have no internet connection on any of my computers. If I plug the dsl cable directly from my model to one of my computers, I have an internet connection. Yesterday, after about 4 hours of lights flashing, they suddenly stopped and were solid. I had no problems for the rest of the day. This morning, same problem, lights flashing rapidly and no internet. This is causing me major problems because I work from home and need to start working at 7:00am. Any suggestions?
Thanks,
DJ
  • Lucid_Dream2 Apr 16, 2008
    Thanks for the input. My first thought was the power supply, however the power light is the only light that doesn't flash. Unfortunately, I don't have another power supply to try. When I came home from work tonight, lights were still flashing and no internet. About a half hour later, they stopped flashing and the internet started working all by itself. I don't want to buy a new router unless I'm sure it's going to fix the problem. Any other thoughts would be appreciated.
    Thanks,
    Dana
    Scholar:
  • 60 Answers
You seem to have a problem with the switch or its power supply. If you have another D-Link device with the same power supply (see the volts and amps on the sticker), we may try switching them.
I one had a problem very similar to yours and changing the power supply solved the problem.
Posted on Apr 16, 2008
  • Jocelyn Viau
    Jocelyn Viau Apr 17, 2008
    Unfortunately there is not much else to try than a spare part since this kind of switch is very simple.
    If your switch is still under warranty (1 year) you may call D-Link's tech support. If it is out of warranty, you may try to buy a new one (exact same model) in a store that has a 30-day money back policy and try the new power supply. If it works, return the switch (be honnest and return the working power supply too) and call D-Link part department to get a replacement, I think it cost around 20$.
Same thing happened to me all you have to do is remove all the cables attached to your switch then reconnect it, the lights will stop blinking progressively and the switch will be fine again
Posted on May 04, 2009
    Problem Solver:
  • 12 Answers
One possible solution, I have seen this many times on various small desktop switches, is that a slight power flicker will lock them up. Power cycling(unplug power for about 10 secs) the switch should fix the issue, and a good power-conditioning battery backup will prevent it.
Posted on Mar 02, 2010
Has anyone come up with a solution yet? Does a D-link-5+ switching device have to be programed to the Broadband Router? If so how do you do it?
Lots of flashing except the power light with no internet.
This use to work fine,do they go bad after so much use? Lots of Questions ,but does anyone have any answers.
Posted on Feb 05, 2010
I have four of these switches and three of them have the same problem as yours. The power supplies were not the problem because my known good switch would work with them.
Posted on May 05, 2008
I have an Internet Connectivity problem which I believe was caused by resetting our D-Link WBR-2310 router. We have a strange, perhaps illogical network setup in our office. Although it was set up before...
It appears you are not using the wireless connections on both the routers and the reason for using Router B was that there were insufficient LAN ports on Router A to connect to the two workstations that are connected to Router B.
To simplify your network, I suggest you replace Router B with a network hub or ethernet switch and connect the two workstations to this network hub/switch, then configure these two workstation to Obtain an IP address automatically. Router A will then issue IP address to these workstations via the network hub/switch.
Jul 09, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
When I plug a cable into the computer from the switch, I am getting ethernet cable unplug error. I know the cable is good and my router is set up correctly. I have 15 computers using this switch and only...
check individual IP of your computer..try to obtain each PC..let you router assign the ip.check your router maybe you need to add addition numbers of clients.
Jun 26, 2011 | D-Link DSS 16 Plus (DSS-16+) 16x10/100...
I have a D-Link DSS-16+ and I was wondering if I could plug the dsl modem in any port on it and will it work? Thanks
The DSS means that this is a switch, not a router. This means that you will need a router between your modem and the switch. Switches are usually used in workplaces where there are many machines connecting to the internet with wired connections. For home use, most things connect wirelessly. The reason why you need a router is because a switch cannot create internal IP addresses like a router can. It can only pass on the IP information.
Jun 17, 2011 | D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps...
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I need to ask about my problem. I just bought a D-Link DES-1008D and a D-Link DIR-300 Wireless-G Router my problem is after I attach 7 computers on my switch hub. I only have limited local network...
Make sure you're using a crossover ethernet cable to connect the router to the switch. Also make sure that the router has it's DHCP server up and running.
Nov 03, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Dlink DI-614 router wont stay online!
I would start with the simple things first:
1) reseast the ethernet cables
2) change the ethernet cable
3) change to different port on the router
4) uninstall/reinstall drivers
5) run spyware cleaner and anti-virus
Feb 15, 2009 | D-Link AirPlus DI-614+ Wireless Router
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
ENET Port issue on BEFW11S4 Wireless Router
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Apr 02, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
D-link dss-5 setup (please help!)
you need to make sure that DHCP is enabled in the router settings and that your network cards TCP/IP is set to obtain an ip address automatically.
Also check that your computers workgroup is the same as your friends eg, Home or Workgroup.
Nov 03, 2007 | D-Link Express EtherNetwork DSS-5+...
D-Link Express EtherNetwork DSS-5+ (NTSWDLDSS5PL) Logo
8,908 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
