Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv32fq86u tv
When set is switched on have sound only then 3 loud clicks red light on front of tv flashes twice
  • 4,234 Answers
Teh 2 blinks indicate an overcurent condition. The most common cause of this is a shorted horizontal output transistor. Look for a 3-legged part attached to a heat sink close by the flyback transformer (part with red wire coming out of the top). Replace that part. That may resolve the problem. That part will be marked C5438 or something similar. If the marking is as I stated than the actual part number is 2SC5438.
Please realize that other defective parts can cause similar problems. I have just listed the most common. Please keep us posted.
Dan
Posted on Apr 16, 2008
My tv keeps making a loud clicking noice
Does the set just click on and then right back off? Do you have Flashing power Light on Front or is TV playing with Loud Clicking?
Oct 07, 2012 | Sony SELECT KDF-E50A12U Rear Projection...
I want to control my Sony DAV-HDX576WF with my Comcast remote control and need the remote control code.
Reposting from multiple sources.
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TVicon1.png/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951Power = 32719Mute = 33743
Good luck. Let me know if it works.
Also, to program your remote to function volume controls while in CBL or TV mode without switching between modes to change the volume, see below. Source http://www.hifi-remote.com/forums/viewtopic.php?t=8831Quote:Locking Volume Control To TV or AUX Mode:
1. Press and hold SETUP until the Red light flashes twice, then release SETUP.
2. Enter 9 - 9 - 3 (Red light will flash twice).
3. Press and release either TV or AUX (Red light for selected device will flash twice).
Jan 29, 2012 | Sony BRAVIA® DAV-HDX576WF Theater System...
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
NO PIC OR SOUND WHEN TURNING ON THE T.V. JUST A LOUD CLICK SOUND WHEN PUSHING THE BUTTON TO TURN ON. THE RED LIGHT AT BOTTOM JUST FLASES LIKE IT DOES WHEN IT WAS WORKING BEFORE SHOWING THE PIC. IS IT FIX...
YES IT IS FIX ABLE LOOK FOR A SONY SERVICE CENTER, CHEAPER IN LONG RUN. COUNT THE FLASHES IT SHOULD PAUSE AND BLINK AGAIN FROM LIGHT ON FRONT. DIAGNOSTICS FOR THE TECH.
Apr 15, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
TV won't turn on, red light flashes twice
your tv has hardware problem and Sony service person can fix it.
Jul 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a sony kv32fq86u tv on start up have sound only tv clicks 3 times and red light flashes twice
Usually the 3 blinks indicate an overvoltage condition in the B+ power suplpy. I'll look up your sepcific model and try to provide you with specifics.
Dan
Apr 16, 2008 | Televison & Video
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
271 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
