Sony VAIO VGN-N250E/B Notebook Logo
Posted on Jun 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have no system recovery disc but i want to factory setting
I have no system recovery disc but i want to restore factory setting in my laptop without starting windows
Lee Hodgson
Level 3:
  • Sony Master 4,810 Answers
  • Posted on Jun 28, 2010
Lee Hodgson
Sony Master
Level 3:
Answers
4810
Questions
Helped
1782531
Points
15941
Providing the laptop was built after 2005 then there should be a recovery partition on the laptop.
Turn the laptop on and repeatedly press the F10 key, this should get you into the recovery partition and allow you to factory restore the laptop.
Regards.
  • evertonian Sep 02, 2010
    hi leecom72
    once in the recovery partition, what to choose?? step by step pls.. i dont know dos language..
    thanks
What F? Key do I press to restore my Fujitsu Siemens amilo L7320GW
Fujitsu simens back to factory settings
Downloads & Disks Regarding The Reset Factory Settings Fujitsu Amilo Li 2727
http://www.user-guides.co.uk/download/reset/resetfactory/reset-factory-settings-fujitsu-amilo-li-2727.html
Fujitsu Laptop to Factory Settings
Restoring the factory settings on your Fujitsu laptop is a great way to get rid of files associated with programs that have been removed from your computer that are taking up space and get rid of pesky viruses that you can't remove from your machine by any other means.
Restoring the factory settings on your laptop can also help resolve problems with an unstable laptop.
You should also restore the factory settings on your laptop if you plan on selling it or giving it to a family member or friend.
Restart or turn on your Fujitsu laptop. Press "F12" repeatedly when the Fujitsu logo appears on the screen to be redirected to the Boot Menu.
Highlight "Recovery and Utility" using the arrow keys on the keyboard, then press "Enter."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files.
When the files have been loaded, the System Recovery Options window will be displayed.
Select a keyboard layout, then click "Next." The Operating System dialog box appears.
Choose "Use recovery tools...," then click "Next." If prompted, type your administrator password, then press "OK." The System Recovery Options window will appear again.
Select the "Recovery" tab, then click "Restoring the Factory Image (only C:\drive)."
The restoration process will begin, and the laptop will be restored to its original factory settings.
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen.
Begin personalizing your copy of Windows.
Using Boot Disc
Highlight "CD/DVD" using the arrow keys, then press "Enter."
Place the boot disc that came with your Fujitsu laptop in the optical drive, then click "OK."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files. When the files have been loaded, the System Recovery Options window will be displayed.
Click "Next" when the Operating System dialog box appears.
If prompted, type your administrator password, then select "OK."
Click "Recovery and Utility" when the System Recovery Options window opens, then select the "Recovery" tab.
Click "Restoring the Factory Image (only C: drive)."
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen. Begin personalizing your copy of Windows.
Saving and recovering your factory and system images.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/HDD Restore Generic-Multi-lang B6FJ-3031-03EN-00.pdf
Restoring compaq presario to factory settings 2500 without disc
Why not remove the virus with your up-to-date Anti Virus software? Or you freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL scan , delete ALL results, reboot. If you have a Factory Recovery Partition,You can find the Factory Recovery procedure: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=242213&prodTypeId=321957&objectID=c00006110
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.
if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
I set a password to my laptop and I can't remember what it is, how can I get to use my laptop again??
@pinkruthpink
The quickiest way to reset your password is to run System Recovery (aside paying someone from a local computer store and use a software to reset it). Gateway laptops have a built-in recovery mode on the system wherein you can restore the computer to factory default without using a restore discs. (please note that this will erase everything). The hotkey for the recovery is the ALT+F10 key. After you press the power button, you need to hold ALT key and then simultaneously press the F10 key.. Once the recovery menu has loaded, click Restore to Factory Default Settings.
Good luck
1helpful
My system Acer 7720G was reformated but i intended to restore back to factory settings. How do i restore to factory setting without the recovery disc. Thanks. Okeniyi Michael
You need to get the orignal acer installation disc which came with the laptop. That would be able to send it to default for you. Any other installation you do can't send it to the factory settings.
Selling my Toshiba laptop and I want to restore it to default/factory settings. When this was bought did not come with a disc.
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya
3helpful
4answers
How do you reset to factory settings on the gateway ZX4931-31e
Click on Start -> All Programs -> Scroll down to Gateway (or type Gateway in the line) -> click on Gateway Recovery Management -> click on rider "restore" -> click "Restore System to factory default".
4answers
How to reset the toshiba l30s lap top to factory set up without the set up cd?
There is no way to restore it towards factory settings without the restore disc on your model.
Can i do a factory reset on a satellite a105 s2236 without recovery disc?
since in thosiba systems the restore partition is not there so you require the recovery disc to restore the system to factory settings
1helpful
Restore factory settings for my samsung r519 laptop win7
system restore can do this for you if windows does work
if not recovery disc are sold on line through ebay and other web sites
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
