Disc drawer does not open - Televison & Video
  • klamp Dec 03, 2008
    My Zenith DVB211 DVD Player plays the disc fine, but will not eject.
  • 4,234 Answers
Can you please post the make and model? Without that there is little we can do to help.
Thanks,
Dan
Posted on Apr 16, 2008
How do I get the CD drawer to open?
Normally, there is a small hole located below the disc drawer that you can put a straightened paper-clip in to open the drawer.
Feb 02, 2015 | Audio Players & Recorders
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
When i put in a certain disc, it says unknown disc. It works in my wife's dvd player which is an insignia
Hi...
Try a cleaner disc..Walmart and target sell them.
Or. open the drawer,unplug the AC with drawer open and get a can of dust-off compressed CO2 ( walmart or radio shack) and shoot it into the housing behind the drawer facce
Apr 17, 2010 | Memorex MVDR2102
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
Disc drawer will not open with either the button on the set or the remote control. Display shows "open" the changes to "no disc"
Jan 19, 2010 | Televison & Video
Disc drawer won't open and sometimes doesn't power off
The disc drawer is broken, there are motors that open the drawer (what you hear when turned on and off) and it must of got damaged by a cd or some other way. If you want to open it, pry it open with your fingers or screwdriver. I had to take the 5 cd holders out to see the problem and there was a cd that jammed everything. But you might not have that, take a look. And the "bye bye" thing is normal but not if it wont go off at all.
Oct 06, 2009 | RCA RTD207 System
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Disc drawer sticks
i had this happen when my 460 was standing up. when i "sat it down" the disc drawer opened and closed fine.
Jan 03, 2008 | Microsoft Xbox 360 Console
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Televison & Video Logo
338 people viewed this question
Top Televison & Video Experts
Electro Med Services...
