Question about Hunter Low Profile III 20807 Ceiling Fan
Fan will not run, but light works
My fan is getting power because the lights work, but the fan won't turn at all... No hum... nothing... could the fan switch be bad? Could I replace that? I am fairly handy with soldering and electricty....
  • Anonymous Apr 04, 2009
    I have the same problem. I replaced the pull switch in my fan but it still does not work?
    Genius:
  • 1,036 Answers
Could be the switch. More likely to be a speed controler or the windings of the fan motor itself.
Turn all power off, and remove it, then check the switch first, the windings next, and look at the controller 3rd.
Posted on Jun 11, 2008
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Have dell Inspiron 546 minitower. Been acting up lately where it won't power up. The LED light on PSU below voltage switch is green. Light on MB is orange. No power or indication at all on front...
PSU's put out several different voltages if the 12Vs isn't working it won't power the motherboard. Some outputs may still be functioning therefore you may see some lights on and even some fans running. Replace the PSU.
Jun 29, 2013 | Computers & Internet
Casablanca fan has totally stopped working
Probably need to reset receiver in fan. call 1-888-227-2178 and somebody should be able to help you with that.
Dec 29, 2012 | Casablanca Fan Dryers
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Hyundai accent 2001 will not start all lights work radio works heater fan works battery in 3 months old when I turn the key all i hear is a humming sound for about 1 min. than nothing. weather has be
The humming would be the fuel pump coming on. It should only hum for a few seconds, then shut off.
Your problem is with the start circuit from the battery to the starter, or from the ignition switch to the starter solenoid. Check the connections at the starter (the big cable) for tightness.
Is the battery charged up enough to turn the engine over? Check by turning headlights on and observe while someone turns key to crank. If they dim a LOT, then either battery is too low, or the starter is bad and needs removing for testing. If brightness doesn't change, then the circuit from ignition switch to starter solenoid is likely not working. Check for 12 volts at the small wire to starter solenoid with key in cranking position. If you have power there, the solenoid may be bad. Remove starter for testing. If no power at solenoid in starting position, then either the ignition switch is bad or the neutral safety switch might be the problem, or the wiring from the switch to the starter solenoid is not passing current.
Good luck.
Jan 14, 2012 | Hyundai Accent Cars & Trucks
Fan won't run at all.
If you plug it in and turn it on, does it "humm".
If so, it is getting power. It could be the blades are stuck on something: do they turn by hand?
The motor could be dirty also, is the blade hard to turn?
It can be repaired by Vornado, or you can dis-assemble the motor and clean it.
Dec 24, 2010 | Vornado Circulating Fan
HP Pavilion a1150y fans run when powered on but windows doesn't load, monitor, mouse and keyboard do not work. (Running Windows XP)
Believe it or not, it's due to a weak power supply. More specifically, weak voltage rail/s caused by failing Electrolytic Capacitors.
A bad computer power supply is about 70% of computer failure.
ALL the light use less than 1 Watt. EACH fan uses 2 to 3 Watts.
A processor uses 55 to 125 Watts. Depends on the make and model.
Since the power supply is weak, it doesn't have enough power to turn the processor on.
No processor, nothing to find the Boot record on the harddrive. Nothing to get the Operating System going. (Example: Windows XP)
No computer running, there is no signal to the monitor.
Just enough power to light lights, and spin fans.
Apr 13, 2009 | HP Computers & Internet
New fan not working but lights work
There is less than 120v getting to the fan. Its possible that the lights will turn on etc. Take an extension cord and plug it in another plug and grab both power wires from the fan and stick them in other end of extension and I do service calls for broan & Nutone
Jean-Marc
try it out. Im sure your not getting 120v completelty.
Feb 05, 2008 | Broan-NuTone Allure QS130SS Kitchen Hood
Hunter Low Profile III 20807 Ceiling Fan Logo
185 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
