Question about HP f2105 21" LCD Monitor
Sleeping Monitor My hp cpu runs perfectly fine. My hp monitor turns on, doesn't read a signal, then the monitor sleeps. Is there any resolution to this?
  • 57 Answers
Check your video card remove from the system then clean up the gold tip second remove the memory then clean up the gold tip then put it back to the board then restart your CPU
Posted on Apr 16, 2008
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Monitor goes to sleep when computor is turned on no input signal
If the monitor is going into sleep mode the normal power led will change to another color. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays on, you have a backlight malfunction. It can be bad capacitors causing an inverter power fault or it may have worn out backlights causing a shutdown condition.
Monitor Mike
Aug 17, 2010 | HP w1907 LCD Monitor
Why the monito out sleep why
Pls check whether your cpu is properly booting because your monitor sleeps out because there is no signal detected coming in from the cpu try to connect your monitor to another cpu so that you can determine the proper operation of the monitor...
Jul 17, 2010 | HP W2007 LCD Monitor
I have an HP w2207 flat screen monitor. I have to
I stoped the monitor from sleeping by going into the montitor's menu, management, then sleep. Turn on the never allow to sleep mode. We were having some of your mentioned issues with the icons and with the monitor not waking up. This fixed that. Now the computer will go to sleep and when started the monitor comes on instantly.
Mar 23, 2010 | HP Computers & Internet
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Jul 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP f2105 21" LCD Monitor Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
