Question about Samsung SyncMaster 1100MB 21" CRT Monitor
Samsung, SyncMaster 1100MB
My monitor vibrates/shakes time to time it is really disturbing
  • 1 more comment
  • rabea May 04, 2008
    hi there, i have a samsung crt syncmaster 793df , i boat it new after one month , its start vibrating.its really annoying , i remove everything related to magnetic feild , like speakers adn ups, and any power source, i even change the frequency to 85hz, but its still the same problem,
    so please any help can you provide..
    thanks
  • idil May 06, 2008
    I wish it was that simple
    I don't have anything around the monitor, ups is not even in the same room (it is central)
    When it starts shaking; degaussing from the menu on the monitor does not fix the problem...
    So I still suffer from the shaking...
  • sachin29feb Jul 31, 2008
    i having same problem with the Samtron 56 V monitor from 2 months, i have done give solution, but no effects on the monitor, so plz give me more suggestion over that.
    thanx
  • 88 Answers
Hi idil that is very simple
in only 4 conditions the monitors shakes like that they are
1. Give 1 feet gap between speakers and the monitor
2. Give 1 feet gap between Ups and the monitor
3. Give 6 feet gap between all the radiation things
4. Check the power voltage up and downs
Thank you
Posted on Apr 16, 2008
Image not focused
Possible worn out tube. The focus adjustment is on the flyback transformer and has to have the back cover removed to access it. The flyback will be a black and have a red wire connecting to the crt tube. This is very high voltage and can be dangerous. With a plastic screwdriver you can turn the focus adjustment knob on the transformer. Do not adjust the screen control knob. If the focus does not clean up, then the tube is probably worn or the flyback is bad.
Nov 27, 2013 | Samsung SyncMaster 1100MB 21" CRT Monitor
There is a bright spot on the middle of screen, of my model no 1100mb. model code ks21cnibhk/xtp
The picture tube is at fault.Since its at the center it indicates that the phospors at the center are burnt/faded & not able to reproduce the colors it was meant to. My advice would be to buy a new monitor since changing the picture tube is not cost effective
Dec 09, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
I have just connected my old (beloved) SyncMaster 1100MB to my new computer with Windows 7. I can only get a refresh rate of max 60 Hz to the monitor. It gives too much flicker. How can I get a higher...
Right click your desktop and select "properties". On the last tab (where you set the resolution) click the "advanced" button. On the new property sheet go to the monitor tab and uncheck the box that say something like "hide modes that this monitor does not support". Click OK then. Now you should have everything up to 200 Hz.
Hope this helps. If you need any more assistance, don't hesitate to come back to me. Else, if the problem is solved, please do ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 05, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
I need driver
No, you don't need a driver. This is a "plug-and-play" device.
Your Operating System (Windows XP??) will adapt to the capabilities of the device.
Jan 07, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
Problem in samsung syncmaster 793MB is that when shaked,colours change but when unshaked,screen is green or blue.is there any solution to this?
hi,
I think there is problem with your display card.
If you could try testing with another monitor you ll get confirmed. In that case you have to purchase another VGA card and install it then it works fine.
Regards
Oct 03, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
After few minutes I have disturbance in picture on SM T200
i have almost the same problem and can't find a solution... hopefully the guy who made my computer know whats wrong with it...
my samsung syncmaster is also connected to the DVi port(digital)
and it's sometimes working for a day and other times for a minute of 5.
and now i get it always in games what i get is:
-screen go black and in the top left corner yuo see analog(VGA port)and then digital(DVI) again.
and this will continue for at least 5 min sometime it stops after that sometimes never and i need to reboot(1of 5 times that work sadly)
-i get a buzz sound while he is doing that.
-sometime i get a green flash in the shape of what i was doing and then he change again.
can anyone help me/us?
Dec 20, 2008 | Samsung SyncMaster T200 LCD Monitor
Picture on monitor is shaking
Make sure you have no fans, radios and type of magnet around yuor monitor.
Then check to see fi you can change the refresh rate to see if that helps.
  • Right-click desktop
  • Go to properties
  • Settings
  • Advanced
  • Monitor Tab
Dec 12, 2008 | Samsung SyncMaster 955 DF 19" CRT Monitor
Samsung Syncmaster 1100MB
hi install your monitor utility and drivers
run the CHKDSK utility
Mar 20, 2008 | Samsung SyncMaster 1100MB 21" CRT Monitor
Samsung SyncMaster 1100MB 21" CRT Monitor Logo
168 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
