Craftsman 25cc Gas Line Trimmer Logo
Posted on Nov 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Craftsman 25cc Gas Line Trimmer dies when giving throttle. It starts up and runs in the "Start" setting, then dies as soon as you give it gas. I replaced the carburetor...it ran great immediately after installing. Two weeks later (which equals only two days of yard work), it is doing the same thing as before. What else could it be?
Richard Haynes
Level 3:
Master:
  • Craftsman Master 673 Answers
  • Posted on Nov 20, 2017
Richard Haynes
Craftsman Master
Level 3:
Master:
Answers
673
Questions
0
Helped
208221
Points
1403
Sounds like the carb is getting clogged. Drain the old fuel and make sure the fuel filter is attached to the fuel hose inside the fuel tank. SeaFoam or a product called Start will sometimes clean the carburetor. If not, you will need to have the carb rebuilt, flushed or replaced.
Also, check your muffler and spark arrest, sometimes if they are clogged, you will have a similar issue.
3 Related Answers
evwood
Paul Evans
  • 50 Answers
  • Posted on Dec 07, 2008
SOURCE: Trimmer starts immediately, then stops
How old is the trimmer? If still under warranty, Sears can fix this. If not, then my experience has been the problem is a bad coil. This is due to heat build up. When the coil gets hot, it shorts out.
Anonymous
  • 155 Answers
  • Posted on Jul 26, 2009
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Anonymous
  • Posted on Aug 28, 2009
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
This if for a Craftsman Weed trimmer
SOLVED: Craftsman 25cc Gas Line Trimmer dies when giving - Fixya
www.fixya.com/support/t5186018-craftsman_25cc_gas_line_trimmer_dies
1 answer
Nov 11, 2017 - Drain the old fuel and make sure the fuel filter is attached to the fuel hose ... SeaFoam or a product called Start will sometimes clean the ... Craftsman gas 25cc weedwacker starts, runs a few secs, then dies. The gas take up line is disconnected or is broken. ... You should be fine for next season that way. I have a Troybilt TB10CS trimmer that starts and ...
Oct 20, 2012
Craftsman 29cc dies when depressing throttle
Aug 27, 2012
SOLVED: My craftsman p2 weed eater won't stay ...
Aug 6, 2012
SOLVED: Weed eater bogs down when i try to give ...
Sep 15, 2010
More results from www.fixya.com
Why does my craftsman 2-cycle model 316.791860. Gas trimmer die?
Those little carbs clog very easily and what you experience is a common symptom. Go to any bog box home store and in the mower area pick up a can of small engine carb cleaner.
Remove the carb, take it apart as far as you comfortably can and soak all pieces in a can/jar of CLEAN gasoline for 10 -15 mins. Agitate to get the gas moving.
Remove the carb, and drip clean then use the carb cleaner to blow out every port you can see. reassemble and install the carb, it should work fine.
Before storing for the winter drain all gas from the tank and start it allowing the machine to run till it stalls out due to no gas. You should be fine for next season that way.
My 7-year old 25cc Craftsman line trimmer began surging during use, would bog down when given throttle, then would completely die, became hard-starting, and now doesn't start and run at all. Acts like...
A new fuel filter with new fuel lines and a rebuild kit for the carburetor should do it. You may even be able to get away with just the gasket and diaphragm kit for the carburetor. It is cheaper than the complete rebuild kit if you choose. Run synthetic oil and these things will last a good long while.
4helpful
Craftsman 25cc weedwacker (358.791030). Zama carburator (C1U-W19) Just rebuilt carb but did not adjust low speed/high speed screws. Starts on first pull (with choke lever actuated), and after warm up,...
need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
Machine will start but won't stay running. give some gas and it runs for a couple of seconds and then dies. i did replace the spark plug but it is doing the same thing. it is a 25cc craftsman weedwacker...
I had a similar problem and it was simple to fix. I hope yours is the same. The line going into the gas tank is not far enough down in the tank.Once you prime it with the primer bulb , it will run till that gas is gone. No fuel from the tank is getting to the carburetor. If you've replaced the fuel lines recently, this may be your problem. If not, try cleaning the fuel tank and the carburetor. Hope this helps.
3helpful
My 32cc starts right up but as soon as i give it gas it stops...help
The low side carburetor adjustment screw needs to be turned counter-clockwise. Start by turning it 1/4 turn then test run. If your carb has plastic locks on the screws, they will have to be removed first. Most modern carbs require a special tool to adjust the jets. The tool can usually be purchased from your local repair shop.
2helpful
Trimmer wont stay running after i give it the gas. Drained tank. Changed spark plug. Runs while choke is on and pull up on the throttle. As soon as i let off on the throttle and try to throttle up again it...
You're on the right track, but it sounds like you have a carburetor issue...might be time for a rebuild kit or just a cleaning. This doesn't always fix every carb however...You can first try cleaning your carb....very sensitive parts inside....use only brake parts cleaner or WD-40 or the like...even most carb sprays are too harsh.There are lots of diagrams and helpful hints on carb web sites...just don't "soak" the carb in cleaner if it's dirty. Older machines accumulate carbon in their muffler and engine and periodically need to be cleaned. It's not that hard to do and it will help you learn how your machine works also.
2helpful
I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
21helpful
4answers
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
