Question about PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres
Dead motherboard i bought a pcchips a13g+ socket am2 motherboard from is the second one i recieved ,both dead. no post.only fans running i installed PNY 2gb memory one gb on each slot also bought athlon 64x2 5400 also reset cmos nothing helped
  • Peter Thompson
    Peter Thompson May 11, 2010
    Did you have a PCI-e video card or were you using the onboard?
Maybe it's your cpu not seated properly. or it's burnt.
Posted on May 08, 2008
Tengo un problema dengo una de estas placas madre pero el que la armo no le puso la bocina interna para detectar los podrian decirme donde se conectaria ya que perdi el manual y de esa manera podel localizar la falla ya que si prende el ventilador del procesador y el disco duro pero no aparece nada en el monitor dice que no hay señal de entrada.
Posted on Oct 07, 2008
Put cardboard under the motherboard and install all components. What is happening is the board is shorting out on the case. These solder points on the bottom ofthe motherboard are generally too big. I ran into the problem you're having when I tried to install a second stick of ram. It wasn't until I found a way to sort of pull the board away from the case. Sometimes you just have to put a permanent barrier there. First try the cardboard thing though.
Posted on Sep 10, 2008
Did you connect the four-pin power connector to the motherboard? I had the same issue. Also did you connect the speaker? The MB does not have a built in speaker, you have to plug in the little one that comes with it.
Posted on May 02, 2008
  • 176 Answers
Do you hear some noise or beeping when you turn on the switch. try to clean the memory slot maybe there is a lot of dust that cause the contact connection fail. Try also to remove the battery and ower the motherboard if still not working try to replace a new battery. Because there is some motherboard that if the battery is dead or very low voltage the motherboard is not working
Posted on Apr 17, 2008
Jan 20, 2014 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Need manual for pc chips a13g+v3.0
- If 3 short beeps than DIMM memory not properly inserted or memory failure
- If 1 long beep and 8 short beeps than VGA not detected
Jan 10, 2014 | Pcchips PC CHIPS A13G V3.0 Socket AM2/...
Driver a13g+v3.0a
Under Downloads, click the BIOS, Driver or Manual tab: (be sure to download the correct file[s] for your OS)
PCChips A13G+ Ver3.0A
Jan 07, 2010 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Pcchips a13g drivers
hry there, you can find it at the following link
Jun 12, 2009 | PC Chips PCChips A13G+ v3.0 Motherboard -...
tenho problemas para instalar a minha impressora multifuncional da HP com o cabo é usb, acusa que o cabo está desconectado.
Já tentei em todas as portas usb e não consigo concluir.
Minha placa mãe é PC CHIPS A13G+ v 3 . 0
socket AM2 cpu
May 23, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres Logo
237 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
