Question about Palm TX Handheld
Palm TX erratic touchscreen
Poor to useless input using the touchscreen.
Cleaned around edges of screen with thin cards and no help.
Digitizer does not work: Selected the "bulls eye" target over 450 times and it will not go away.
Removed many 3rd party software and no improvement
"ON/OFF" switch broken so I cannot do a Hard Reset.
? Any other way to do a Hard Reset.
? How to open the case so I can really clean around the edge of the screen
? Any other suggestions
Many thanks,
  • 3 more comments
  • Bafunno May 13, 2008
    I constantly have to go to "Preferences" and "Touchscreen" to recalibrate the pen - but it drifts after about 10 minutes and I need to recalibrate
  • Anonymous May 27, 2008
    I can use the bottom buttons to turn on different views. The stylus will not work or change to get into the calendar or other applications.
  • cdiep Dec 22, 2008
    My TX will run regularly for a few minutes/days, and all of a sudden I won't be able to write letters on the touchscreen anymore. The only buttons that will work are the actual buttons. I've tried calibrating it probably a hundred times. Should I try to do a hard reset before anything else? Can anyone explain what is going on here?
  • Anonymous Mar 30, 2009
    no support or info from palm (absolutely rediculous) they seem to be ignoring the problem. I'll never buy another from them & I make sure to voice that opinion whenever topic comes up with others.
  • pkolstad Mar 30, 2009
    Very erratic behavior of touchscreen for some time. Now I can't get it to respond at all.
I just tried Power Digi and also found it works like a charm!
Posted on May 13, 2009
"Power Digi" from http://www.palmpowerups.com/news.php. Try The 2 week trial then buy it for $16.95. Worked great. Don't let the trial run out without buying it because it'll be worse than before. Touchscreen failure is endemic with TX and some other Palm devices. I'm a faithful Palm customer for nearly 10 years but they're losing chunks of market share with this fiasco. I'm pretty much committed to Palm OS because of how much I use it for now. Still looking to switch.
Posted on Sep 23, 2008
  • 100 Answers
Change the screen. You can have the part here, as well as directions on how to change it:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390
Posted on Apr 20, 2008
    Problem Solver:
  • 14 Answers
Well you can perform a Hard reset on the device to resolve the issue or you can also contact Palm support to send the device to repair. The web address is www.kb.palm.com
Posted on Dec 25, 2008
Touchscreen will not work on my Samsung Brightside SCH-U380
Other than a bad digitizer (touchscreen) or connection, sometimes just a tiny bit of gunk/debris gets in that tiny gap that goes around the outside of the screen. That often results in the same problem,, a non-working touchscreen. Take a very thin edged piece if cut plastic as a "tool" to clear out gunk/debris from this gap around the edge of the screen. Some people even have used like the opposite end of a sewing needle (not the pointed end).
Many ppl have fixed a non-working screen simply by cleaning out this tiny edge gunk. Give that a shot as a first step. If you use care, you won't damage anything.
Oct 28, 2014 | Samsung Verizon Brightside Sch-u380 Black...
Touch screen can not be calaberated
Then the touchscreen is most likely faulty and would need to be replaced, unfortunately you may have to replace the entire screen as it may be difficult to remove the digitizer from the top of the lcd display if its glued in.
Dec 05, 2010 | Palm TX Handheld
Palm TX is going crazy
It sounds like something I had trouble with before.
There is probably either a pinch in the unit (like it got slightly kinked when dropped, or there is some debris under the edge of the screen causing it to calibrate or touch improperly. I would suggest taking your drivers license and run it just under the edge of the frame. It should dislodge any problem matter and allow it to work properly but you will probably need to recalibrate your digitizer. Good luck!
Dec 21, 2009 | Palm TX Handheld
BOTTOM OF SCREEN NOT WORKING,
This happens a lot with Palm digitizers. The only permanent solution is replace the plastic digitizer with an upgraded glass type. Before considering that, see if removing screen protector helps. (yeah, didn't think so. Worth a try!) Try Powerdigi, a better calibration program. Get it from http://www.palmpowerups.com
It worked for me.
Jul 03, 2009 | Palm TX Handheld
Palm T/X touch pad not responding
pls reset the device like this and then align it
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=7125,E=0000000000337448967,K=6865,Sxi=8,case=obj(887)#hard
if problem persists then yes u are gettin screen alignment problem bcoz of digitizer fault it is faulty u want to do it then go to below link
buy the digitizer and change it urself see the video
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PA1693&Category_Code=_TUNG
PLS RATE ME FIXYA FOR THE HELP
Mar 20, 2009 | Palm TX Handheld
Palm TX Touchscreen does not work
Search youtube for Palm TX Digitizer Replacement and Palm TX Take Apart Direction. If you think you can do it, or know someone who can, you can order a replacement digitizer on ebay for from somewhere like www.pdaparts.com.
Before ordering the part, you may want to start by opening the palm and cleaning the connecting ribbon cable contacts to make sure that a loose cable or oxidation has not caused your problem.
Feb 03, 2009 | Palm TX Handheld
Palm TX: Digitizer problems - can't use all functions; i.e.all those on bottom row of screen. Soft reset and touch-screen alinement exercise doesn't seem to work.
I developed the same problem after owning my TX for about a year and a half. I found an acceptable solution by experimenting with the digitizer. Instead of tapping the very center of the bullseye, I tapped off center until I found an acceptable setting where accessing functions anywhere on the screen would work for me.
Nov 14, 2008 | Palm TX Handheld
PALM Z22
Your problem might be a simple one. Hopefully so:
Run a business card around the edges of the screen between the screen and the plastic housing to see if there is any trapped dirt or other debri. If there is, it will hold down that point of the screen and prevent any further input. Be sure to remove anything you find.
Also, sometimes the screen protectors themselves will shift just enough to cause the same issue. Be sure it is not wedged tightly between the screen and case.
I hope this is it and helps!
Aug 29, 2008 | Palm Z22 Handheld
Touch Screen does not work at all
My touchscreen was acting batty, not responding where I was touching. The solution for me was to:
1. remove my screen protector
2. Take a piece of paper, fold it in half, and scoop under the lip the case where it holds the touchscreen in to fish out debris that were distorting how the digitizer recorded.
Nov 14, 2007 | Palm TX Handheld
Can't get past the calibration page, keeps shutting off
Does the calibrator keep looping or not seem to work?
If you can access the calibrator, but it loops through the target sequence (repeatedly asking you to tap the targets), there may be a physical problem that's causing your touchscreen to be confused:
  • Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
  • You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame.
  • A heavy impact or scrape to the touchscreen can cause permanent damage. If your touchscreen is damaged, you may need a repair
Did you install any 3rd party apps?
?St=2,E=0000000000825403011,K=4996,Sxi=18,Case=Obj(26419)
Diagnosing problems by 3rd parties- http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?
New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908)
Aug 31, 2007 | HP iPAQ RX3715 Pocket PC
Palm TX Handheld Logo
498 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
