Maytag washer goes off balance even w/o a load in basket, machine is level on floor, what is used to internally balance the basket?
  • jcallaway Apr 09, 2009
    same problem whirlpool washer
Maytags use different methods of balancing depending on model. Which machine do you have?
Posted on Apr 16, 2008
    Champion:
  • 207 Answers
Several shock absorbers are used to internally balance the basket. Most likely they need to be replaced. It is a typical malfunction. Not expensive and can be done quickly by experienced DIY guy.
Washer has been shaking ever snice it was moved to have new floor installed.
Most likely your washer is not balanced evenly on the floor; get a level and level the washer accordingly. You can use shims to get it leveled. Also Home Depot or Lowes Home Improvement stores have something called Vibration Pads. I would take care of it before using your washer again since the shaking might cause problems to the actual washing machine.
Apr 11, 2013 | Maytag MAV7200 Top Load Washer
Leveled washer gets out of balance when load in spin cycle
A vibration problem is about the hardest thing to diagnose long distance but I will give you the most common things to look for.
Shipping brackets and materials not removed from the machine. You should be able to move the basket around easily by hand. Go over the installation instructions and make sure everything has been removed.
Leveling legs and lock nuts misadjusted or loose. You want the legs adjusted as low to the floor as possible. The higher it sits, the more movement it has.
Weak floor. If you can stomp the floor and have pictures rattle on the wall, you will have vibration problems with the washer. If it is on a laminate hardwood floor, you will have vibration problems. These floors have too much bounce for a washing machine.
The tub support to stiff causing too much vibration to be transferred to the cabinet or not allowing the tub/basket to return to the upright position so that it starts an out of balance spin. Put the washer into a cycle and let it agitate. Before it goes into a spin, open the lid and see if it is leaning awkwardly to one side. If the washer has some years on it, this may be your problem. If you remove the front panel you will see the thick washer the whole unit sits on. If it seems the unit is stiff , you may try spraying a LITTLE wd40 on the base it sits on so it slides easier, but just a little.
Check these things out and you should find your problem.
Thanks/Mike
Oct 24, 2007 | Washing Machines
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washer doesn't sit level in new laundry room
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
In order to check properly for internal issues,unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or rocking, is the floor on which the washer sits. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 23, 2010 | GE WSXH208A Front Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My front load washer "walks across the tile floor", it is level, what can I do
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Very noisey. It is balanced & level. Horrible vibration
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Jan 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washer tub vibration on spin cycle--machine will walk across floor
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is istalled.
Jan 01, 2010 | Maytag Washing Machines
My Maytag neptune is extremly loud
Dec 14, 2009 | Maytag Dryers
My Maytag goes out of balance and bangs loudly
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports.
There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four.
If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled.
Oct 30, 2009 | Maytag HAV2557 Top Load Washer
Washing Machines Logo
566 people viewed this question
Top Washing Machines Experts
