Question about Dell 924 All-in-One InkJet Printer
Printing Problems I purchased new ink cartridges from dell now when I print a page the ink on the paper has tiny white lines going trough the letters. I tried cleaning the cartridge like the printer suggest but that still doesn't work. How do I fix this?
    Scholar:
  • 41 Answers
To resolve this issue , execute the following steps
1. Unplug the power adapter from the printer
2. open the printer cover and look for the transparent plastic strip behind he cartridge holders, ,wipe the strip using a soft cloth.
3. connect the printer to your computer and on your computer , click on start , All programs , Dell printers, Dell AIO 924 , and then click on All in one center, a new window opens up , Click on maintenance and Troubleshoot tab (which you would find on the top in All in one center)
4.you will get a new box for maintenance and troubleshoot, in that you will get an option, Clean to Fix horizontal Streaks , click on that and it will print a page ..
Follow these steps and it will resolve the issue.
Posted on Apr 21, 2008
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Missing lines of print
hello
You either have to change the ink cartridge or try to clean the ink cartridge nozzles as described in the user manual;
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
On page 54 it states the following:
To clean the ink cartridge nozzles:
1 Load plain paper. For more information, see "Loading Paper" on page 19.
2 In Windows XP, click Start-Control Panel-Printers and Other Hardware-Printers and
Faxes.
In Windows 2000, click Start-Settings-Printers.
3 Right-click the Dell Photo AIO Printer 924 icon.
4 Click Printing Preferences.
The Printing Preferences dialog box opens.
5 Click the Maintenance tab.
6 Click Clean Print Cartridges.
7 If the print quality has not improved, click Print Again.
8 Print your document again to verify the improved print quality.
9 If you are not satisfied with the print quality, wipe the ink cartridge nozzles, and then print
your document again.
hope this helps.
Feb 17, 2012 | Dell 924 All-in-One InkJet Printer
I have installed new cartridges the colour prints perfect but the black is blurred with lies through it. i also found a small t shaped rubber piece about about 4mm x 6mm in the paper tray could this be the...
this rubber piece can be actually locket from printer rollers, but, returning to your smudgy printing
1. remove cartridges from the printer
2. check if there is bit of paper stuck anywhere in paper path, if so, remove
3. check if rollers on paper path are clean
4. touch bottom of the cartridge with absorbent tissue to check if ink is flowing through, if yes then insert cartridges back and print test page.
5. if cartridge do not allow inkflow, check what solvent is used (water, isopropyl alcohol or methylated spirit - this which do not cause precipitation is correct solvent), soak absorbent paper (tissue) with proper solvent and whipe head of the cartridge with it, 6. put drop of the solvent on golden knobs inside seats of the cartridges of the printer, allow it to soak in, wipe off with lint free tissue and put another drop of solvent in. allow soak in,
7. install cartridges back, print test page, it should start printing very weak and improving as it goes through the page (solvent will be printed first)
8. create "strip page" one line yellow, white space, one line cyan, white, magenta, white, black - print that page, this print will clean printheads and establish good inkflow.
all ink printers must print at least one page per week as to keep heads free of gum and ink in flow.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
White line along right side with black ink only
One of our IT guys came out and said he had figured out the solution on another printer with the exact problem. The problem is that the ink cartridge is not in tightly enough. It LOOKS like it is; the lock is even shut and the drum rolls smoothly. BUT, there is a tiny, and I mean tiny, bit of space between the cartridge and the drum, thus the ink gap. So, the solution is to be sure the cartridge is pushed back into position very tightly. We had been tentative in shoving the cartridge in because of the plastic pieces, but the lock locked just fine and we heard a slight clicking sound. Now we know to put it in carefully, then push hard into place. Problem solved.
Jan 07, 2010 | Dell 3100cn Laser Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
Prints like it is running out of ink, but it is a new cartridge. Some sentences are printing, others are blank, or partially printing.Followed instructions to align and clean nozzles. Doesn't help.
HTML clipboardIf you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Dell 946 All-In-One InkJet Printer
Dell 946 Printer
check on the series of the ink cartridge you got
946 all in one's has a lot of series for the cartridge
Sep 19, 2009 | Dell A940 All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 720 printer won't print
Our Dell AIO A940 stopped printing black ink. Tried so many things, and finally (a year later) got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
It's worth a try! Good luck!
Oct 23, 2007 | Dell Inkjet 720 Printer
Dell 924 All-in-One InkJet Printer Logo
98 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
