Whirlpool washer motor hum
10 year old whirlpool top loading washer.
THe pump was leaking I replaced it with a new on. After that the washer would fill but not spin or agitate. the motor hummms. THe washer did work before the pump replacement. help? PLease..
  • Anonymous Mar 30, 2014
    10 plus years old...LOVE it... but it's not spinning well anymore. Have to manually set it to 'spin' with each load. But that is no longer working either...Doesn't seem to spin that fast anymore either. Solutions to look for?
  • 1,073 Answers
You may have a bad pump stuck take the pump back off you should be able to turn the pump by sticking your finger in the slot that it slides up on the motor shaft if it turns with a little resistance the pump is ok if it will not turn then it needs to be replaced
also check to make sure that the motor connector wiring is tight and the lid switch connector is tight also
Posted on Apr 16, 2008
Whirlpool ultimate care extra large, about 10 years old. when the machine is in spin cycle, it throws the circuit breaker. It started with a heavy load, but now it seems to do it all the time. It started...
Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
Jan 03, 2018 | Whirlpool LSW9700P Top Load Washer
My washer has completely stopped still hums and water goes in but will not drain or agitate. the last few loads made the machine smell like burning rubber. its at least 10 years old and has...
It is not uncommon for the water pump to lock up causing the belt to burn and even melt the drive motor pulley. Tip the machine back and check the pump. It should be easy to turn. The bearing will lock slap up on these type pumps with nary a water leak. To replace the pump you need a 3/8th nutdriver and a pair of channel lock pliers. You remove 2 hoses and 3 bolts.
Jul 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
Washer won't agitate. New timer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load, direct drive Whirlpool / Kenmore washers use a reversing motor.
It turns one way for agitating and reverses for draining and spinning.
It sounds as if either the motor is shot or one of the connectors is bad.
As a place to start, see the Whirlpool Service manuasl (with wiring diagrams) for their top load, direct drive washers.
Feb 13, 2010 | Kenmore 24832 Top Load Washer
Leaks when filling
It could be a swollen impeller inside the pump causing it to wear a hole in the plastic housing and making the humming noise .It,s fairley easy to replace as it clips on to the end of the motor.Hope this helps.
Nov 28, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer motor hums....
have you tried the timer switch?
Jun 19, 2009 | Whirlpool LSR7333 Top Load Washer
Washer only fills. then completly dead.(timer still advance)
is there any humming coming from under or front of your washer? whirlpool built machines for about 10 years now are "direct drive" ...the motor has a plastic coupling held in place by a rubberish plastic donut type of thing, its an inexpensive fix and there are videos on youtube on how its repaired..its under 10 bucks and usually cures any lack of agitation/ spinning ...i had a roper by whirlpool and once i replaced it from a parts machine i salvaged it was fine.. so check you motor coupler/ coupling and that maybe your answer, if not there is a set of wires and a cut off in back of the motor to prevent overheating, which may have tripped..also a good point to check.. good luck
Apr 30, 2009 | Amana NTW5100TQ Top Load Washer
Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Oct 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Cabrio Leaks Water
Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
Aug 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
