Question about Indesit WA 125 Front Load Washer
Indesit w93 Hi I cant work out how to take out the filter i can turn and unlock it and drain the water but cant work out how to get to the filter to clean it any ideas?
    Champion:
  • 207 Answers
Below the door, there's a plastic cover several inches tall, full machine width. Just remove it and on the right you'll see the filter. Make sure machine is unplugged. Unscrew the filter counter clockwise, clean it, check the pump blades and inlet for some foreign objects and screw filter back on.
Posted on Apr 16, 2008
You need to take the 4 screws out too, before the filter can be removed.
Posted on May 28, 2008
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
Machine doesn't discharge fully
check that the out let pump filter is clear first,, then check that the drain pump is working,, it may be blocked up or stuck so it cant turn or maybe the drive motor has burnd out or the drain away pipe could be a little blocked up
Jul 01, 2010 | Indesit WA 125 Front Load Washer
Indesit w93 is not rinsing,
this is most likley to be the programer brain its gone fulty on you,, its not a cheep part to get fixed sorry
Oct 26, 2009 | Washing Machines
Indesit W93, the light flashes but does not work
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Mar 29, 2009 | Indesit W 123 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Indesit W93 washing machine
i have same problem and have had a srvice engineer change almost everything on my machine with no success....
Jan 09, 2007 | Indesit WA 125 Front Load Washer
Indesit WA 125 Front Load Washer Logo
519 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
