Question about HP PSC 2210 All-In-One InkJet Printer
Kindlly assist hp 2210 problem narrow paper
I have an hp 2210 printer i replaced the cartriges then after the printer refused to alige the cartrige instead it displays a message narror paper replace wider paper and press enter to continure ave tried to put in diffrent sizes of papers but it coulnt work still displays the same message
  • 3 more comments
  • Anonymous Jun 02, 2008
    Have the same problem and tried this solution. Didn't work. Any other suggestions?
  • WHAC Jun 05, 2008
    paper too narrow display
    there is no jam & when press enter the same display comes up????????????????????????????
    did i just buy another hp junker!!
  • shelylaska Aug 31, 2008
    changed the ink cartridge and when it tries to print align cartridge report the it claims the paper is either too narrow or mismatch paper. Does this with fax printing also. getting worse.
  • vulien May 04, 2009
    I have the same problem. Tried restores default setting, still error " paper too narrow, load wider paper". Please help.
  • kseattle May 10, 2009
    Same problem, says "paper too narrow" press arrow to align cartridges. Then it says printing in progress, busy etc. It will not clear and print. do I need to uninstall and re-install again?
  • 975 Answers
You have to go to the menu and change the settings , try the DEFAULT setting . also do you have the printer connected to the PC ?
Posted on Apr 18, 2008
My HP Officejet 5615 All-in -One shows "Papierstau" (paper jam) though there is no sheet or piece of paper in it.It then also sometimes shows first "aligning cartriges" and then "paper jam" and then...
Unplug your printer. Then wait 40 seconds and plug it back in. Check if you have enough ink in your cartridges.
If all else fails replace ink cartridges.
They make paper that has alcohol on them and you can run it through your printer to clean those sensors. Just hit Cltrl and P at the same time.
May 18, 2017 | HP Officejet 5615...
HP 7310 Cartrige Belt Repair
The right end is connected with an idle pulley on a spring. If you grab the left end and pull it to the left, the spring will strech. This will help to attach the belt to the carriage motor on the left.
In some printers the spring streching is fixed by screw that have to be loosen first.
If you can't reach the motor's weel on the left, you have to take off some parts first.
Aug 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Printing blank paper
At a guess you've bought a compatible generic cartrige. I had a similar problem different printer.
I had to by a genuine cartrige, worked fine. Contacted the generic cartrige provider, explained the problem. Returned cartriges and got refund no problem.
It looks like the generic cartrige makers are seeing some solutions to chipped cartridges but not all.
Mar 13, 2010 | Dell 922 All-In-One InkJet Printer
How do you install ink cartriges in my hp 2210
Hi! Click on the link below, or if it doesn't work, copy and paste to your browser address window. It will walk you through removing and installing cartridges on your printer. Hope this helps! Hal
Jun 08, 2009 | HP PSC 2210 All-In-One InkJet Printer
New ink cartridge
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 all-in-one
My computer will not allign right. It says paper is too narrow...insert wider paper...then refuses to do task . All the paper is the same. It is not the paper. What do I do?
Jan 09, 2008 | HP Printer/Scanner/Copier 2210 Ink-jet...
Hp psc 2210 all in one printer
pls.. align the carriage , or re insert the two cartrige's
Apr 22, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
414 people viewed this question
Ben Johnson
