Question about Philips cBright SV2 Multimedia Projector
Philips sv2 lc4431
Put new bulb in machine starts up but wont illuminate then buttons on top go red
  • 563 Answers
Hi there
Did you reset the lamp timer ?
Posted on Apr 16, 2008
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Philips 32PW9617/79 wont work. flashing red light. wont turn on. heard a bang before it went off.
Yeah. that bang was most likely the bulb. They are meant to be replaced from time to time.
Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 12, 2010 | Televison & Video
Bulb Replacement
It might be the the socket board on this model not the crt tube. Closely look at each tube these tubes end up contaminated. They start looking like lemonade inside. Usually the blue and green, with the tv off see if the green and blue are as clear as the red with a flashlight. You might want to call a service center. Cheaper in the long run over the cost of a tube.
Apr 17, 2009 | Philips 60PP9753 60" Rear Projection...
Philips DVD hard drive recorder HDRW720 locks up
Do you have a disc locked up inside?
I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Mar 26, 2009 | Philips HDRW720 DVD Recorder
Light
From left to right
1. The wrench light is the service interval light.It will illuminate after about 4800 miles or 358 days to remind you your vehicle is due for service.To reset hold the SELECT and UNITS buttons on the trip computer for 5 secs. The light will illuminate then extinguish itself after about 4 secs.
2. Frost warning light. This light illuminates yellow when exterior temps are between 39 to 32 deg. F to warn you of possible icing on the roads.It will illuminate red if temps drop below 32 Deg.
3. Brake pad warning. Will illuminate when brake pads have worn down to the sensors in the pads.
4. Washer fluid warning.
5. Door Ad-jar
6. Bulb failure. Indicates an exterior bulb is out.This will illuminate until brake pedal is pressed after starting engine unless of course one of the brake lamp bulbs is burnt out.
Feb 26, 2009 | 1999 Mercury Cougar
Lamp light flashing
hi during my investigating i found that the eletrorode surge arrester was causing the problem epcos component 800 083 number i found a device from a projection tv and it worked i also checked epcos web site but could not the accurute device number . they will ask u to use a ruler to measure the device size of the component thanks
Jan 10, 2009 | Philips LCA3123 Projector Lamp for Bsure...
Philips sv2 lc4431
Hi
If the lamp timer has been reset , then you might be looking at a faulty Ballast ( lamp's powersupply )
Apr 16, 2008 | Office Equipment & Supplies
Indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Mar 31, 2008 | Indesit W 123 Front Load Washer
Philips cBright SV2 Multimedia Projector Logo
217 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
