Question about Cameras
I Put my memory card (SD 1.0 GB) in the computer to take photo's from it and in a hurry i pulled it out without safely removing it or anything. now when i turn it on it says 'this memory card is protected' and wont let me do anything eg none of the buttons work??
    Novelist:
  • 155 Answers
It sounds as if something has got messed up on the card
Did you get all the photos off the card that you wanted to? If so, try the following:
Put the card back in the computer. Go to 'My Computer', right-click on the icon for the memory card and select 'Format'. (WARNING - Doing this will wipe any data from the card!)
Once your done, try it in the camera again. Hopefully all should be OK again.
It might also be worth reformatting the card with the camera itself. It shouldn't make any difference, but some people recommend this.
Hope this helps,
Matt
Posted on Apr 16, 2008
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
I have a 1 GB/Kingston SD card in my Samsung SC-D363 NTSC Camcorder, and I need to know a Free Download Photo Software that can Pull up my videos to my computer.
Try this link @ http://www.samsung.com/us/support/downloads/SC-D363
Alternatively,
If your SD memory card is removable you can remove your SD card and use a USB card reader to transfer your files to your desired folder location to your PC.
Hope it helps.
Feb 20, 2011 | Computers & Internet
Will a SD 2gb memory card work in my hp 620 digital camera?
Yes, any Secure Digital (SD) memory card can be put into your hp Photosmart 620 camera safely. I would not go any bigger than 4 GB due to the limitations of some computers that you may use to download and process your photographs. And, you probably will want to pull off the phototgraphs and put them onto your computer for long term storage or for printing. That camera normally makes about a 1 Mb file for a JPEG image file. It will take a long time for you to fill up a 2 GB card; around 2,000 photographs.
Oct 12, 2010 | HP Photosmart 620 Digital Camera
After deleting photos from the memory card, it now says "card not initialized", when put back into the camera, none of the functions seem to fix it, can you help?
If your pics are safely on your computer, follow these rules: 1. Never erase pics using the computer...always use the camera. 2. Never remove anything from the computer USB ports without using the "safely remove hardware" function. 3. Now, your card needs to be formatted in the camera.
Aug 10, 2010 | Fuji Finepix A510 Digital Camera
I lost the usb cable for my camera and am trying to remove images from the internal sd card. how can i do this?
For your USB
> Contact kodak store at 1 888 369 6600 ask for KODAK USB Cable, Model U-8 or simply log on to www.kodak.com/go/shop.
To remove images from the internal memory of the camera
1. Turn the Mode dial to Favorites
2. Press the Menu button
3. Highlight delete or the minus icon, then press the OK button.
All pictures stored in the Favorites section of internal memory are removed.
4. Press the Menu button to exit the menu
** Kodak CD33 has 16 MB internal memory and it has a slot for MEMORY CARD 3428db8.jpginternal memory is different to memory card. You can use the camera without memory card but it's only up to 16MB while if your using s memory card you can load up to SD Memory Card 2 GB.
16MB if camera is set to 2MP it will only take about 2-5 photos while if your using a Memory card with a size of 1GB and camera is set to 2MP about 1137 photos.
* Contact Kodak support line @ 1 800 235 6325 (23KODAK)
Nov 16, 2009 | Kodak EasyShare CD33 Digital Camera
Infected SD Card? or Computer?
This can happen when the card is removed when Windows is still accessing it. Even when you think you are not doing something, Windows could be. I am 99% certain there is nothing malicious on your system and the cause was early ejection.
To prevent this from happening next time, before removing the SD card try using the "Safely Remove Hardware" tray icon to safely remove your device. TIP: Do not remove any storage device (i.e. SD Card, Flash drive, etc.) if the light is blinking.
Happy computing!
Sep 18, 2008 | SanDisk Memory Media
What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Jul 13, 2008 | Kodak EasyShare V1003 Digital Camera
Unlock 1 GB micro sd memory card of Kingston Made
just perchase the usb card uncloker clip and put the card within the second card will unlock ..
May 30, 2008 | Nokia 6233 Cellular Phone
Formatting an SD disk
Try to your computer management by right click on my computer icon then click manage then look for disk management. If you can see your removable drive exist, please right click then explore it.
Hope you will approved to make my rate solved.
Best regards,
Philip
Nov 14, 2007 | Electronics - Others
Micro SD card wont work
type 277634# * # (no spaces)
click port setting
click mass storage
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
Nov 01, 2007 | LG CU500 Cellular Phone
Cameras Logo
98 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
